11-04-2008 01:28 AM - edited 03-15-2019 02:20 PM
Hi expert,
i have CME where PRI and 1 FXO line is terminated, i want to make FXO line as a private line for one xtension let say 606, i configured it and it was wroking fine but i want to use this line only for international dialing and local and national calls should go thru PRI
ephone-dn 1
number 606
trunk 82
voice-port 0/1/0
connection plar opx 606
dial-peer voice 1 pots
destination-pattern 82
Port 0/1/0
i llappreciate if somebody suggest any solution
11-05-2008 09:00 AM
great Allan
but last confusion if i dont create trunk 82 even then this will be remain Private line for number 606
and nobody can use this FXO line except 606
i ll make these changes tomorrow morning
thanks again
11-05-2008 09:15 AM
For all intense purposes 82 should remain transparent to all users, unless they become aware of it and dial the number directly with 82.......
Only International calls made by extension 606 starting 900 will be translated transparently to the user and use 82.
If this access number becomes common knowledge, then simply change the translation pattern rule to use another number and change the POTs dial-peer pattern:-
For example, use 55:-
voice translation-rule 82
rule 1 /^900\(.+\)/ /5500\1/
rule 2 /^9\(.+\)/ /9\1/
voice translation-profile User606
translate called 82 (this doesn't change)
dial-peer voice 204 pots
destination-pattern 55T
Allan.
11-05-2008 09:42 AM
ok thanks
but there is no such solution vailable by we can restrict a particular line to particular extension
becuase i saw that solution where u just need to define trunk number under the ephone-dn
actually i tested that solution but after applying that line can only be restricted to that particular FXO port
anyways that solution is already working fine
i tested with diferent access code and translation rule
anyhow you really put a laot of effort to help me
it was a agreat experince to share with you
i ll get in touch with you
thanks
take care
