Problem CUCM- HTTP Status 500
amar.elazzouzy
hello ,
I have a problem for conncter on the Web intérface (Http://IP) of sub-CUCM I have an error message: The  server encountered the year internal error that prevented it from fulfilling this request
attached the error message .
Amar
10 Replies 10
Rajan
Hi Amar,
have you tried restarting tomcat service on the sub ?
Rajan
yes , but I have the same problem
Best Regards
Amar
Did you install this file "cisco.cm.11_0_struts_2_3_32_upgrade.cop.sgn" recently ?
Yes  exactly .
There is a beug at cisco.cm.11_0_struts_2_3_32_upgrade.cop.sgn ?
Amar
Yes,
Please download the newer version of that COP file and install it again.
File is called
Rev 2 of COP file to address CSCvd49840 in CUCM 11.X.
ciscocm.11_X_struts_2_3_32_upgrade_v2.cop.sgn
File is version dependant, please get the one for your current CUCM version
with ciscocm.11_X_struts_2_3_32_upgrade_v2.cop.sgn i have the same problem
AMAR
Hello Amar,
Please refer to this bug CSCve44018, as it is a side bug for the original CSCvd49840.
There is a note that states.
NOTE: Even with this fix, ciscocm.11_5_struts_2_3_32_upgrade_v2.cop.sgn will only work with 11.5.1SU1 and higher. If it is applied on any versions older than this, there will still be web pages that are not accessible. The only workaround is to upgrade to 11.5.1SU1 or higher and then re-apply ciscocm.11_5_struts_2_3_32_upgrade_v2.cop.sgn.
Hi Jaime ,
My version of CUCM is : 11.0  i cant upgarde directly to :
In that case you should use ciscocm.11_0_struts_2_3_32_upgrade_v2.cop.sgn
You will find it here.
https://software.cisco.com/download/release.html?mdfid=286284802&flowid=77897&softwareid=282204704&release=DAT&relind=AVAILABLE&rellifecycle=&reltype=latest
Hey Amar, Can you remember what you did to fix this as I have exactly the same after loading 2_3_35 in cucm version 11.0?
Paul
