Problem on Hunt pilot,Hunt_List,Line_group
d.kepmegni
Hello
here is my Hunt list configuration
1. on the hunt pilot 9082807
     if busy go to the voicemail
      if no answer go to the voicemail  timeout 30
 on the  LG_815-TEST_LAB i configured these options
       algorithm : diffuser
       TNA 18 seconde
no answer : try next member,then try next group
busy : stop hunting
not availaible :try next member,then try next group
 on the  LG_815-TEST_LAB200 i configured these options
       TNA 25 seconde
busy : try next member,then try next group
after i make a test , no answer and not availaible condition is work fine
but the busy condition transfert the call to next group instead  of to go on the voicemail
what can be the problem ? thank you for help me please
9082807 INTERNE Hunt Pilot
HL_815-TEST_LAB
    LG_815-TEST_LAB
         5082803, INTERNE
         5082801, INTERNE
    LG_815-TEST_LAB200
        9082101, INTERNE
        9082103, INTERNE
Can you make sure that your second line group has busy option as stop hunting.
