Problem on QSIG link between 2811 and Alcatel 4400
malosse
Hello
I've problem with QSIG link.
Architecture:
I've 2811 connected to OMNI PCX 4400 Alcatel with QSIG link.
On the OMNI PCX, i've, MOH device when i call specific number.
Problem:
When i call the "specific number" from my Ip phone connected on my LAN behind the router 2811, the call are OK. I listen the MOH and after short time, the called agent hang off is phone => OK!
When i call the same specific number from outside, the caller doesn't listen MOH. However, the called agent is ringged and can hang on the call ...
Changed done without effect:
- We have also changed the identity of the caller from translation pattern ...
- We have change Plan:ISDN, Type:National to unknown, unknown ...
Does anyone can help me ?
15 Replies 15
What kind of cable did you use a straight one or :
1               4
2               5
4               1
5               2
