Problem with cisco 3905 SIP Phones
Dragan Talevski
I have registered 10 cisco ip phone 3905(SIP) and 2 7945 (SCCP) on CUCME 9.1 . Communicaton between 3905 and 7945, and outside to PSTN works. i have configured dial-peer to other call manager 6.1. calling from 7945 to phones registered on call manager(7911) is working perfectly. When I make a calls to phones registered on call manager(7911) ringing is working but i cannot established connection (audio drops). Calling from 7911 to 3905 is workink also. Codec is OK, CSS is OK. sip to h323 and h323 to sip is ok. I think that i have some problem with SIP signaling. please advise.
3905----CUCME-------CUCM-------7911
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
  h225 timeout tcp establish 3
voice register global
mode cme
source-address 172.22.255.1 port 5060
max-dn 50
max-pool 25
load 3905 CP3905.9-2-1-0
authenticate register
authenticate realm lukoil.local
timezone 24
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0001409928815001
voice register dn  3
number 303
allow watch
name x
label x
voice register dn  4
number 304
allow watch
name y
label y
voice register pool  3
id mac xxxx.xxxx.xxxx
type 3905
number 1 dn 3
dtmf-relay rtp-nte sip-kpml cisco-rtp sip-notify
voice-class codec 1
username 303 password X
description X
voice register pool  4
type 3905
number 1 dn 4
voice-class codec 1
username 304 password Y
description Y
interface GigabitEthernet0/0
ip address 172.22.255.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip ospf message-digest-key 10 md5 xxxx
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.22.255.1
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:apps45.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:term45.default.loads
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:APP3905.9-2-1-0.zz
tftp-server flash:CP3905.9-2-1-0.loads
tftp-server flash:term65.default.loads
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:apps31.9-2-1TH1-13.sbn
tftp-server flash:cnu31.9-2-1TH1-13.sbn
tftp-server flash:cvm31sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp31.9-2-1TH1-13.sbn
tftp-server flash:jar31sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP31.9-2-1S.loads
tftp-server flash:term31.default.loads
dial-peer voice 100 voip
destination-pattern [12]..
session target ipv4:172.21.93.150
voice-class codec 1
dtmf-relay cisco-rtp rtp-nte h245-signal h245-alphanumeric
no vad
presence
sip-ua
presence enable
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 50
ip source-address 172.22.255.1 port 2000
timeouts interdigit 4
system message LUKOIL Montenegro
cnf-file location flash:
load 7931 SCCP31.9-2-1S
load 7945 SCCP45.9-2-1S
time-zone 24
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Oct 18 2012 22:08:56
ephone-dn  1  dual-line
number 301
label x
name x
allow watch
ephone  1
device-security-mode none
description x
mac-address xxxx.xxxx.xxxx
type 7945
button  1:1 2w2
Dragan Talevski
I added enable faststart on gateway setting in call manager and everything worked
