External SIP Trunk Registration not staying up- Drops after every call
rka61
Hi All
I am hoping you can help me with a problem that I am facing with sip trunk registration. I am newbiee to setting up CCME so please bear with me
Scenario: Have a Cisco 1861 router running c1861-spservicesk9-mz.152-2.T1.bin on which i have installed CCME
The router is also acting as my home ADSL router. I have 2 hard phones plugged into it and both phones register and I can all each other internally no problems. Both Cisco phone are running SCCP.
I have setup a SIP trunk with voipdiscount.com and when I reboot the router the SIP trunk come up automically and I have configured CCME for outbound call only at this time and it all works fine.
Version of CCME
Version 9.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
Problem: After about an hour or so of no activity the SIP registration drops and when I try to make any outbound calls I just get the engaged tone. When I run this command it show the registration as down.
Cisco1861#show sip-ua register st
Line                             peer       expires(sec) registered P-Associ-URI
5001                             20001      119          no
5002                             20002      119          no
5003                             20003      120          no
rka61xxx                            -1         119          no
rka61xxx is the SIP trunk
Workaround: Only way to bring the SIP trunk back up all I have to do is ping the sip trunk I am using
Cisco1861#ping sip.voipdiscount.com
Translating "sip.voipdiscount.com"...domain server (8.8.8.8) [OK]
Sending 5, 100-byte ICMP Echos to 77.72.169.131, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/49/52 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/52/52 ms
Then if I wait a minute and then run this command the SIP trunk is back up
5001                             20001      2847         yes
5002                             20002      2846         yes
5003                             20003      2847         yes
rka61xxx                            -1         2846         yes
Now I can make outbound calls. But if I make a call and hangup and make another call I get the engaged tone and the SIP trunk goes down again.
I do not know why this is the case and have to ping it again to bring it back up as you can imagine this is very frustrating. I have contacted my SIP provider and they do not state the problem is at there end. These are the SIP details to use http://www.voipdiscount.com/sip
I am attaching my config
version 15.2
service password-encryption
hostname Cisco1861
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 18
dot11 syslog
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.41 10.255.255.254
ip dhcp pool LAN
import all
network 10.0.0.0 255.255.255.0
update dns
dns-server 8.8.8.8 8.8.4.4
default-router 10.0.0.253
option 150 ip 10.0.0.253
lease 10
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  asserted-id pai
  localhost dns:home.org
  outbound-proxy dns:sip.voipdiscount.com
  options-ping 1080
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice-card 0
crypto pki trustpoint TP-self-signed-2714521566
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2714521566
revocation-check none
rsakeypair TP-self-signed-2714521566
crypto pki certificate chain TP-self-signed-2714521566
certificate self-signed 01
license udi pid C1861-SRST-C-F/K9 sn FCZ122760P7
file privilege 0
username admin privilege 15 password xxxx
username xxxx privilege 15 password xxxx
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 4
interface FastEthernet0/0
no ip address
duplex full
speed 100
interface FastEthernet0/0.10
interface Integrated-Service-Engine0/0
no ip address
interface FastEthernet0/1/0
description ##Vu Duo+##
no ip address
duplex full
speed 100
interface FastEthernet0/1/1
description ##NetGear Powerline Adaptor##
no ip address
duplex full
speed 100
interface FastEthernet0/1/2
description ##Sony DVD Player##
no ip address
duplex full
speed 100
interface FastEthernet0/1/3
description ##Qnap 210##
no ip address
duplex full
speed 100
interface FastEthernet0/1/4
description ##Cisco 1142##
no ip address
duplex half
speed 100
interface FastEthernet0/1/5
description ##Spare##
no ip address
duplex full
speed 100
interface FastEthernet0/1/6
no ip address
duplex full
speed 100
interface FastEthernet0/1/7
no ip address
duplex full
speed 100
interface FastEthernet0/1/8
no ip address
duplex full
speed 100
interface ATM0/2/0
no ip address
ip mask-reply
ip directed-broadcast
no atm ilmi-keepalive
interface ATM0/2/0.1 point-to-point
description ##WAN##
ip mask-reply
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Vlan1
description ##LAN##
ip address 10.0.0.253 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
description ##ADSL TALK TALK ISP##
ip address negotiated
ip mask-reply
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxx
ppp chap password xxxxxx
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 110 interface Dialer0 overload
ip nat inside source static tcp 10.0.0.43 80 interface Dialer0 80
ip nat inside source static tcp 10.0.0.43 8080 interface Dialer0 8080
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 110 deny   ip 10.0.0.0 0.0.0.255 14.1.1.0 0.0.0.255
access-list 110 permit ip 10.0.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
tftp-server flash:ip_phones
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:cvm70sccp.9-2-1TH1-13.sb alias cvm70sccp.9-2-1TH1-13.sb
tftp-server flash:term70.default.loads alias term70.default.loads
tftp-server flash:term71.default.loads alias term71.default.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
mgcp profile default
dial-peer voice 1 voip
destination-pattern 0T
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay sip-notify
gateway
timer receive-rtp 1200
sip-ua
credentials username rka61xxx password xxx realm sip.voipdiscount.com
keepalive target dns:sip.voipdiscount.com
authentication username rka61xxx password xxxx realm sip.voipdiscount.com
no remote-party-id
timers connect 100
registrar dns:sip.voipdiscount.com expires 3600
sip-server dns:sip.voipdiscount.com
connection-reuse
telephony-service
max-ephones 10
max-dn 10
ip source-address 10.0.0.253 port 2000
system message A Communication System
cnf-file location flash:
load 7970 SCCP70.9-2-1S.loads
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 02 2012 23:43:24
ephone-dn  1  dual-line
number 5001
ephone-dn  2  dual-line
number 5002
ephone-dn  3  dual-line
number 5003
ephone  1
description ##7945##
mac-address 0023.0434.9EDA
button  1:1
ephone  2
description ##7970##
mac-address 001B.5494.9CDE
button  1:3
line con 0
exec-timeout 20 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0
privilege level 15
logging synchronous
login local
transport input ssh
line vty 1 4
privilege level 15
login local
transport input none
ntp server 212.13.195.4
ntp server 82.219.4.30
ntp server 62.84.188.34
end
I would really appreciate any tips and pointers from anyone. My end goal is to have the SIP trunk registration stay up so I can make outbound calls and not have to ping to bring the trunk up after every call.
Many thanks in advance for you help
rka61
Hi All
After reading some of the forums I found this discussion sounds very similar to my issue do not know if it is bug in the IOS
https://supportforums.cisco.com/thread/2170046
If someone could please confirm my suspicion.
Rushad
