07-07-2008 12:29 PM - edited 03-15-2019 11:47 AM
Hi, i have a CCM 6 and Unity Connection 2.0 with IVR,all work fine, but i try to connect the lines of the old PBX to FXO card, but when i try to call the line ringing but dont send to IVR.
This is part of the configuration
voice-port 0/2/2
timeouts call-disconnect 2
connection plar opx 3022
description Linea 3265323
caller-id enable
This gateway is configured in H323
Thanks regards,
Carlos
07-07-2008 12:43 PM
do you already have a dial peer for 3022 and that DN configured in CUCM to go to VM??
javalenc
if this helps, please rate
07-07-2008 12:55 PM
The configuration of dial-peer is :
dial-peer voice 550 voip
destination-pattern *32T
session target ipv4:172.16.4.1
incoming called-number ....
dtmf-relay h245-alphanumeric
codec g711alaw
ip qos dscp cs5 media
07-07-2008 01:11 PM
does it work if you change it to?:
destination-pattern 32..
javalenc
07-07-2008 01:25 PM
i change taht and nothing.
but i execute this comand :
GW#sh voice port 0/2/2
Foreign Exchange Office 0/2/2 Slot is 0, Sub-unit is 2, Port is 2
Type of VoicePort is FXO
Operation State is DOWN
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is Linea 3265323
and appear that.
07-07-2008 02:36 PM
then go to voice port config and do a shut / no shut
javalenc
