08-19-2014 05:12 PM - edited 03-16-2019 11:48 PM
We have a CUCM ver 8.6.2.22900-9.
For our PSTN access we have the following scheme:
CUCM <========> Cisco2911 <======> ISP-------> PSTN
H323 tk SIP tk
Our Cisco2911 is running ver 150-1.M4.
We configure Cisco 2911 as H323 gateway on CUCM, and we established a SIP tk with our ISP.
When we tested incoming calls we received them at router but they are unable to acceess CUCM,
When we tested outgoing calls we got reorder tone and they did not reach our voice gateway.
We run "debug cch323 all" and tested with one incoming and one outgoing call, and we got the out on attached file "debug h323 forum"
CUCM Ip : 10.1.2.2
Router's H323 int: 10.2.2.1
Do you have any idea about the root cause?
Can be an access list problem preventing proper H323 traffic??
Thanks in advanced
Enrique
08-20-2014 07:38 AM
Do you have voip dial-peers pointing back to your cucm from your gateway? If not then the call wouldn't route onward to the cucm, but the gateway would also ignore communications from that souce because of toll fraud prevention.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
08-20-2014 08:06 AM
duplicate
https://supportforums.cisco.com/discussion/12282486/problem-h323-gateway
08-20-2014 07:40 AM
Collect debug voice ccapi inout for inbound and outbound call and also attach your 2911 config.
08-20-2014 08:11 PM
Hi Afmmanicke and Manish !!!
Jaime is right, I do not how this case has been duplicated, but at:
I attached debugs applied, and configuration of router.
Thanks in advanced
Enrique
