Problem with license CUCM 9
ben Zecharia
Hello ,
 I  am using CUCM version  9.1.2.10000-28
Right now the system is operating with insuffcient license (19 left ) .
Please look at the picture to see license status .
As far as I understand my problem is that I am using 3 enhanced  license I use .
The problem is when  I associate these devices to CUWL user the license report does not change .
I don't know if it's related but I get some errors when I connect to the console of the PUB and SUB .
Any idea ?
6 Replies 6
Rajan
Hi Ben,
From the screenshot, What I see is you have total of 34 CUWL std licenses. CUWL standard license will be used only if more than 2 devices have been assigned the same Owner user id in device configuration page.
If only one device is associated with one device, it will consume license based on device type. For example, 79xx series phones consumes 1 enhanced.
If two devices are assigned to one user, instead of 2 enhanced, it needs 1 enhanced plus
If more than 2 devices and upto 10 devices are associated with one user, then it needs only 1 cuwl standard license
As per your current configuration,
3 devices have been associated with only one user each and will need enhanced license
12 devices have been associated with two users each, hence needs enhanced plus license
Since you do not have enhanced and enhanced plus licenses, these are borrowed from higher tier license (cuwl std) available and hence you are running short of (22+12 consumed all 34 cuwl) 3 licenses.
To resolve this, do the following:
assign the same user associated with the devices which are consuming enhanced plus licenses for one more device in the owner user id field on the device configuration page
Assign the user associated with device consuming enhanced license for few more devices so that instead of consuming 3 enhanced licenses, it will consume 1 cuwl standard licenses
After this update license usage in CUCM and sync licenses in ELM.
Rajan
Pls rate all useful posts
Hi ,
Thank you for the quick respone .
When I click on user to see which phones I need to associate I get blank page (look at the picture  attached ) .
The user you are using for login has privilege to access this. Also try with any other browser.
I am using the admin user and it's the same for other browsers .
When I try to click on enhanced plus I can see the users .
ok.Can you check the devices which are using enhanced license. it might not have users associated.
[+5] to Rajan.
Hi Ben,
please have a look into the bug
CUCM 9.1.2 can't display Enhanced license user in license report
CSCuo36568
Description
Symptom:
In CUCM 9.1.2, System > License> Report,
Enhanced license type > Users
click Users will only show "xx records found" instead of the user details like UserID, First Name, Last Name, Device Count, etc.
Conditions:
It's only happening for Enhanced license type. Have tried on all others (CUWL Standard, Enhanced Plus, etc), all work fine.
Have tested on UCM 9.1.1 and verified that it worked fine. Versions 9.1.2 and 10.0 appear affected.
Workaround:
N/A.
Further Problem Description:
Known Affected Releases:
(3)
10.0(1.10000.24)
9.1(2.10000.28)
9.1(2.11900.12
Known Fixed Releases:
(12)
10.0(1.12008.1)
10.5(0.98000.687)
10.5(1.11001.1)
10.5(1.11900.13)
10.5(1.98000.34)
10.5(2.10000.5)
11.0(0.98100.18)
11.5(0.98000.108)
11.5(0.98000.126)
9.1(2.12039.1)
9.1(2.12900.11)
9.1(2.12900.7)
