12-27-2010 12:49 PM - edited 03-16-2019 02:36 AM
Hello members,
i have a problem with the configuration of the Mobile Voice Access Feature, I am using a CUCM 8.0.2 with a SIP Gateway.
It seems that the application starts but i do not hear any prompt. The call terminates in less than a second.
from the VXML application log i get this errors.
159451: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_media_done:
CALL_ERROR; fail with vapp error 2, protocol_status_code=0
159452: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_cancel_hotword:
159453: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_event_proc:
<event>: event=error.noresource status=0
159454: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_expr_eval:
expr=(var _event='error.noresource')
159455: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_jse_global_switch:
switch to scope(anonymous)
159456: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_expr_eval:
expr=(var _message=undefined)
159457: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_default_event_handler:
use default event handler
159458: Dec 27 2010 21:38:35: //-1//VXML:/vxml_default_event_prompt: Enter
159459: Dec 27 2010 21:38:35: //14722//AFW_:/vapp_session_exit_event_name: Exit Event error.noresource
159460: Dec 27 2010 21:38:35: //14722/1C8D423CBACB/VXML:/vxml_load_immediate_done:
sidp->status=10
The complete log files is attached.
thanks for any comments.
regards
Alex
12-27-2010 01:12 PM
Does the incoming dial-peer (not outgoing!) have a incoming called-number value equal to the Mobile Voice Access Directory Number configured within CUCM under Media Resources > Mobile Voice Access?
Is the partition configured on this page within the SIP trunk's CSS?
Is there a Locale selected?
Is the Cisco Unified Mobile Voice Access Service running on the publisher and 10.0.128.4 is the IPv4 address for your publisher?
12-27-2010 01:35 PM
Thank your quick reply,
here comes the output from the debug voice call ccapi inout
159740: Dec 27 2010 22:18:17: //-1/A8189547BB26/CCAPI/cc_api_call_setup_ind_common:
Interface=0x68ECF8C0, Call Info(
Calling Number=796081505,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=584119901(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=584119901, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=14807
>>>>CCAPI handed cid 14807 with tag 584119901 to app "_ManagedAppProcess_CCM"
i think the call is transferred to the app. the log files is attached.
the 10.0.128.4 is my cucm the voice gateway hast 10.0.128.6.
this is a lab environment, i didn't configure CSS and Partitions.
the config of the my dial-peers is like this.
dial-peer voice 100 voip
description *** Connection to CUCM 1 ***
preference 2
destination-pattern 5841199..
modem passthrough nse codec g711alaw
session protocol sipv2
session target ipv4:10.0.128.4
session transport tcp
incoming called-number 0T
dtmf-relay rtp-nte
codec g711alaw
fax rate 14400
no vad
dial-peer voice 584119901 voip
service ccm
incoming called-number 584119901
codec g711alaw
no vad
the 584119901 matches the number i configured in Media Resources > Mobile Voice Access
regards
alex
12-27-2010 01:42 PM
Your dial-peer configuration is wrong. I said it had to be an incoming dial-peer, not outgoing.
Here is a working example:
application
service cucmmva http://10.101.12.2:8080/ccmivr/pages/IVRMainpage.vxml
!dial-peer voice 4 pots
description INCOMING PSTN to CUCM MVA
service cucmmva
incoming called-number 2625550100
direct-inward-dial
port 0/1/0:23
12-27-2010 01:53 PM
