04-01-2013 06:41 AM - edited 03-16-2019 04:32 PM
Hello all,
I am unable to register a 7911G IP phone with CUCM.
In the status messages there are two repeating errors:
17:15:23 Trust List Update Failed
17:15:59 TFTP Timeout : SEP40F4ECEF476E.cnf.xml.sgn
I tried to reset the phone to factory defaults and register it again but I have no success yet.
Is there anyone that can help with this one? Any suggestions are highly appreciated.
Thanks in advance!
Rosen
04-01-2013 06:58 AM
what is your call manager version ?
regards
Anas
04-01-2013 07:02 AM
Well, the version is 8.something. The CUCM version should be fine, because the phone is able to register from another VLAN.
From the VLAN, that I am currently trying to register it, there is routing and no firewalls to the CUCM.
04-01-2013 07:04 AM
What system are you trying to register it to and what version?
Chris
04-01-2013 07:08 AM
The version is as follows:
System version: 8.6.2.20000-2
04-01-2013 07:16 AM
kindly find the below link. it might help
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080bbcd03.shtml
Anas
please rate if it is helpful
04-01-2013 07:19 AM
I had a look at this one already... tried it... and it is not working for me...
Any other suggestions?
04-01-2013 07:47 AM
Does the option 150 on the DHCP scope for this VLAN point to proper TFTP address? If you review the config of the phone on the phone display do you see proper IP address, and proper TFTP address?
Chris
04-01-2013 07:54 AM
That was my first idea... the DHCP option 150 is configured with the TFTP servers and they are visible in the network configuration page of the phone.
The call manager IP addresses are also visible in the network configuration page of the phone. However, I can see there that it is not specified which is the primary one and which is secondary.
04-01-2013 07:57 AM
This could be an ITL cert issue, can you delete all certs from the phone and see if that helps?
Chris
04-01-2013 08:21 AM
I tried this already as well... doesn't help...
04-01-2013 08:23 AM
So, is the same phone working from different subnet/vlan as you described earlier? Do you have any other phones working on this vlan?
Chris
04-01-2013 08:27 AM
Nope... actually this is a new VLAN that we need to add to the existing setup.
Please find the log of the phone attached.
04-01-2013 08:30 AM
Is this secured cluster?
I see this:
EROR:updateCTL: ** Trust list update failed (have old TList)
Did you delete the CTL certificate as well on the phone?
Chris
04-01-2013 08:33 AM
Yes, we tried it.
