Problem with sessions in Dspfarm profile
Not applicable
I have a problem with the Maximum sessions in DSPFARM Profile.
voice-card 0/1
 dsp services dspfarm
 no watchdog
dspfarm profile 2 transcode
 description CISCO IOS Enhanced Media Termination Point
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g729br8
 codec gsmamr-nb
 maximum sessions 1   // I can't choise another option.
 associate application SCCP
dspfarm profile 1 conference
 description CISCO IOS Enhanced Conference Bridge
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec ilbc
...........................maximum sessions 0   // I can't choise another option.
#show inv
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
PID: ISR4321/K9        , VID: V04, SN: FLM2123V1NN
NAME: "Power Supply Module 0", DESCR: "110W AC Power Supply for Cisco ISR 4320"
PID: PWR-4320-AC       , VID:    , SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4320 Fan Assembly"
PID: ACS-4320-FANASSY  , VID:    , SN:
NAME: "module 0", DESCR: "Cisco ISR4321 Built-In NIM controller"
PID: ISR4321/K9        , VID:    , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-1MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-1MFT-T1/E1    , VID: V04, SN: FOC211936CP
NAME: "subslot 0/1 db module 0", DESCR: "PVDM4-32 Voice DSP Module"
PID: PVDM4-32          , VID: V02, SN: FOC21195J2V
NAME: "NIM subslot 0/2", DESCR: "NIM-2FXO Voice Analog Module"
PID: NIM-2FXO          , VID: V01, SN: FOC204407WW
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 ports Gigabitethernet Module"
PID: ISR4321-2x1GE     , VID: V01, SN: JAB092709EL
NAME: "module R0", DESCR: "Cisco ISR4321 Route Processor"
PID: ISR4321/K9        , VID: V04, SN: FDO21131A6X
NAME: "module F0", DESCR: "Cisco ISR4321 Forwarding Processor"
What should I do?
5 Replies 5
Jaime Valencia
You only have a 32 channel PVDM, and assuming that you already configured that T1, you do not have any more resources, you need to buy and install another PVDM module.
java
if this helps, please rate
Thanks Jaime for your answer, but can I configure with 16 channels the E1 for to have more resources?
Yes, assuming you're receiving a partial PRI from your telco, but with just 16 channels, and using high complexity codecs, you'll get very few sessions with those resources.
java
I understand, then the configuration of E1 would be:
controller E1 0/1/0
 pri-group timeslots 1-15 service mgcp
FYI, we do not support partial PRI with MGCP, you can configure it, but you won't have Cisco support if you need assistance with any problem you face.
That's only supported with H.323
java
