IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5548 Views
  • 14 replies
Hi, I've recently deployed the CUCM 11.5, intergrated with Cisco Unity Connection 11.5 and IM&Presence 11.5. still in testing phase before i role it out to staff however i'm having some issues with the, 1) Dial plans, (Local 07xx - xxxxxx (10 digits)...
abdallahm by Level 1
  • 595 Views
  • 7 replies
hello, i have a ip phone SIP 7841 with firmware ''sip78xx.10-3-1-12'' registred on cme . the problem is when i resstart the ip phone i get this error : error 4 XML . can you help me please Best regards  Akram
Hi All, I have a special requirement. There is a big central core voice network where I have SME and CUCM clusters. On other side I have hundreds of CUCMEs installed in trucks which are mobile units located far away in remote places. When they are re...
khanfawaz by Level 1
  • 1181 Views
  • 8 replies
Hello We are using below mentioned Dial-peer....Current setup we have 001 and 009 for external national/international calls There will be change in Telco ...but DID range we are going to use will be the same ...once the Telco change out going call w...
Hello everyone, I've got a CME 10.5 running on a Cisco 2901 and SPA514G phones registered as SIP phones. I've changed the timeouts, language and timezone but the changes are not taking effect on the phones, that is, they aer keeping their previous se...
by Not applicable
  • 145 Views
  • 1 replies
Hello guys Someone could help me to install, a Cisco IP Phone 7912, i am having a hard time doing it. i already connected all cords, but the IP should configure automatically. but it does not.
helio by Level 1
  • 134 Views
  • 1 replies
Hi everyone! I have the problem that our new 8841 phone is not showing the presence status of called users.We have CUCM 10.5.1.10000-7, presence is working fine with Cisco Jabber.8841 ip phone has the firmware 10-3-1-20 What do we have to do to enabl...
