09-25-2011 09:29 AM - edited 03-16-2019 07:10 AM
Hi there
I've successfully setup Skype to allow incoming calls to our 2851 (+PVDM2) with CUE. Calls to phones are working in so much as the voice is going both ways and is clear. However, if the call is transfered to the CUE, or if the call is endpoint is the CUE directly, the voice from caller to CUE doesn't seem to be being received. I say that because the CUE doesn't record any message from the caller, in addition, the DTMF is being ignored. The attendant playback on the CUE can be heard.
Here is a stripped copy of the configuration, and any help would be appreciated.
Simon
version 12.4
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
notify redirect ip2pots
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
supplementary-service ringback h225-info
fax protocol cisco
cause-code legacy
h323
emptycapability
h225 signal overlap
h225 connect-passthru
call service stop
h245 passthru tcsnonstd-passthru
sip
header-passing
registrar server expires max 3600 min 120
transport switch udp tcp
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class codec 2
codec preference 4 g729r8
voice iec syslog
voice translation-rule 1
rule 1 /^90/ /0/
voice translation-rule 2
rule 1 /1/ /019327550/
voice translation-rule 3
rule 1 // /0/ type national national
rule 2 // /00/ type international international
voice translation-rule 4
rule 1 /7550\(.\)\([13579]\)/ /1\1\2/
rule 7 /7550/ /1/
rule 8 /781151/ /101/
rule 9 /786262/ /100/
rule 10 /1932779997/ /100/
voice translation-rule 5
rule 1 /^0$/ /960/
voice translation-rule 8
rule 1 /^118...$/ /118247/
voice translation-rule 9
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 30
rule 1 /.*/ /640/
voice translation-profile AT_Outbound
translate called 6
voice translation-profile BT_Outbound
translate called 1
voice translation-profile DDI_Inbound
translate called 4
voice translation-profile FAX_Outbound
translate calling 2
voice translation-profile FAX_Outbound_2
translate calling 10
voice translation-profile GSM_Trunk_Outbound
translate called 9
voice translation-profile Prefix-CLI-In
translate calling 3
voice translation-profile Zero_Operator
translate called 5
voice translation-profile skype_to_ccue
translate called 30
voice-card 0
dspfarm
dsp services dspfarm
interface Loopback0
description Do not delete - SDM WebVPN generated interface$FW_INSIDE$
ip address 192.168.252.1 255.255.255.252
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
interface Loopback1
description $FW_INSIDE$
ip address 172.22.0.1 255.255.255.0
interface Loopback2
description Connecting IP gateway for the CUE
ip address 172.21.1.1 255.255.255.252
ip flow ingress
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description Internet interface$FW_OUTSIDE$$ETH-LAN$
ip address XXXXXXXXXX
ip verify unicast reverse-path
no ip proxy-arp
ip flow ingress
ip nat outside
no ip mroute-cache
duplex full
speed 100
no cdp enable
no mop enabled
interface GigabitEthernet0/0.10
interface Service-Engine0/0
ip unnumbered Loopback1
service-module ip address 172.22.0.2 255.255.255.0
service-module ip default-gateway 172.22.0.1
interface GigabitEthernet0/1
no ip address
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 172.20.0.240 255.255.254.0
no ip proxy-arp
ip flow ingress
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 172.21.0.1 255.255.255.0
ip flow ingress
voice-port 0/0/0:15
translation-profile incoming Prefix-CLI-In
cptone GB
sccp local GigabitEthernet0/1.20
sccp ccm 172.20.0.240 identifier 1 version 4.0
sccp
sccp ccm group 1
bind interface Loopback1
associate ccm 1 priority 1
associate profile 2 register skype_cue
associate profile 1 register confprof1
keepalive retries 5
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Skype for SIP
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
dial-peer voice 196 voip
description Cisco Unity Express Pilot Number
huntstop
preference 1
destination-pattern 640
b2bua
session protocol sipv2
session target ipv4:172.22.0.2
dtmf-relay sip-notify
no vad
dial-peer voice 99997 voip
description Dial-peer for incoming skype calls
translation-profile incoming skype_to_ccue
huntstop
preference 1
voice-class sip dtmf-relay force rtp-nte
session target sip-server
incoming called-number 99051000134036
dtmf-relay sip-notify rtp-nte
ip qos dscp cs3 signaling
no vad
sip-ua
credentials username XXXXXXXX password 7 XXXXXXXX realm sip.skype.com
authentication username XXXXXXXX password 7 XXXXXXXX
retry register 10
mwi-server ipv4:172.22.0.2 expires 120 port 5060 transport udp
registrar dns:sip.skype.com expires 3600
presence enable
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 128
sdspfarm tag 1 confprof1
sdspfarm tag 2 skype_cue
conference hardware
no auto-reg-ephone
xml user admin password cisco 15
max-ephones 90
max-dn 120
ip source-address 172.21.0.1 port 2000
auto assign 1 to 10
calling-number initiator
timeouts interdigit 4
timeouts ringing 20
system message Hello
cnf-file location flash:
network-locale GB
load 7906 SCCP11.8-2-2SR2S
load 7911 sccp11.8-4-2s
load 7960-7940 P00308000500
load 7941 SCCP41.8-2-2SR2S
load 7970 SCCP70.8-2-2SR2S
load 7971 SCCP70.8-2-2SR2S
load ata ATA030203SCCP051201A.zup
time-zone 21
time-format 24
date-format dd-mm-yy
live-record 222
voicemail 640
max-conferences 15 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
log password abcd
login timeout 5
fac custom pickup group **3
create cnf-files version-stamp 7960 Sep 07 2011 11:31:39
end
10-09-2011 07:07 AM
I've resolved it. The problem was an access list only allowing udp/5060 when other ports were being opened dynamically.
05-18-2012 03:47 PM
Dear Sir.
I have same your problem , can you explain more how you resolve it ?
Thank you.
Marwan
05-20-2012 01:20 PM
Hi Marwan
Yes, I had to modify the packet filter to allow all UDP traffic from the Skype IP's :
ip access-list extended InternetAccess
remark Remote UDP access to the Skype SIP peers
permit udp host 63.209.144.201 any
permit udp host 204.9.161.165 any
permit udp host 193.120.218.68 any
permit udp host 80.252.85.76 any
permit udp host 78.141.179.70 any
We don't have a skype ddi for each user, only one to the main attendant, so Also, all the ephone-dn's needed to be ammeded, such that
number XXX no-reg primary
kind regards
Simon
