how to identify an incoming phone number in the ivr (CRS)?
HIi have a cisco cme 7.1all configuration regarding time, ntp server(which is the same cme), time-zone, clock set..ect have been configured as below:clocktimezoneYemenT 3ntp master 1ntp server 10.0.2.254 (cme ip address)!telephony-servicetime-zone 31...
Hi Guys,Hope I can seek a little help here. When I tried to configured the time-zone for country Tonga in the CME Telephony-service, I can't seem to have the selection of GMT+13 (equivalent to offset +780 min), the most is +12. Other than adjusting t...
Subject: E1-To-NortelPABX-To-PSTN Migration To E1-Directly-Connected-To-PSTNwhat are the things and configuration to be considered for the implementation of the abovementioned subject?looking forward to hear from you soonthanks and best regards,
What is the timeout for a new call? Is it the T302 timer?Especially, when already in a call, after pushing Transfer, what timer is responsible for determining when to stop waiting for digits, before any digits are dialed.T302 Timer: Required Field Th...
Hi,I could not find any description for compatibility between CME 9.0 and CUE 8.6 on compatibility matrix.Does anybody know any issue if we integrate CME9.0 with CUE8.6?Did anybody try this combination???I just would like to use typical feature like ...
Dears , I am facing directory issue on all of these sets excaept 7942 which is showing perfectly ..any help willl be higly appreciated.
Please let me knwo the procedure to configure ATA 187 [SIP] with CME 8.6 [ 2911 voice router ].
When we add ATA 8.6 to CME 8.6 we are getting the following error message, please let me know what we are missing ?2000/01/01 00:14:39:124 IP phone is in non-secure mode 2000/01/01 00:14:39:254 Succeed to get ATAA418758A2A5E.cnf.xml 2000/01/01 00...
We just upgraded CM from 4.1 to 8.57940 and 7960 phones has fw App Load ID P00308000500 Boot Load ID PC0303010001 Version 8.0(5.0) per compatibility it can upgrade to P00308010100 which is 8.1.1.I loaded files in tftp, restarted tftp and phone still ...
GuysI am having a weird issue here. No matter how to loop my ephone-dns or voice hunt-group or etc. The call will ring out after 1 minute 30 seconds. I do not wish to failover the call to voicemail at the moment. Any ideas?Router#sh run | s ephone-dn...
Hi All, We trying to upgrade the CUCM 8.6.2a restricted version from 6.1.5 SU3 . We gone through the readme document of Refresh cop file 1.1.*** If upgrading from a 6.1(4) or 6.1(5) or 7.1(3) version to an 8.6(x) UNRESTRICTED version, only this ...
Dear all:I need some light to continue troubleshooting a Ring Back tone issue. The problem is that it is only happening when someone calls to the USA DID number from an USA line. ( I tested from an Argentina trunk and Germany trunk and there is RBT)I...
Guys,I am trying to do an export of phones from an existing cucm 4.1 cluster for migration to a new cluster. I observed that BAT does not export all the data. Some phones were missing in the export even though they are present in cucm database.When I...
Dear All ,I have two Cisco Cius and I added the phones on the CUCM 8.6(2) , the phones makes and recives calls normally , my issue is in activating the corprate directory and extenstion mobility services on the Cius phones . so can any one help me in...
Subject | Author | Posted |
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
