problem with translation-rules
kamil_folga
Hi!
I have strip 0 (04441 -> 4441) from called number outgoing call. I have two routers connected via SIP Trunk. Each of the routers have FXS ports with attached analogue phones.
Config router 1:
voice translation-rule 1
 rule 1 /^0\(.*\)/ /\1/
voice translation-profile 1
 translate called 1
dial-peer voice 100 voip
voice translation-profile outgoing 1
destination-pattern 0444.
session target ipv4:192.168.10.2
Config router 2:
dial-peer voice 4441 pots
destination-pattern 4441
port 0/2/0
When I dial 04441 from router 1 I got busy tone.  Phone on FXS 0/2/0 router 2 dont ring. What could be wrong?
Kamil
8 Replies 8
dsobrinho
Level 9
Level 9
Hi Kamil,
Could you please share the topology.
Best regards,
Daniel Sobrinho
Daniel Sobrinho
Have you properly updated the ip trusted list???
java
if this helps, please rate
SIP Trunk working properly if I dont use translation-rules and change dial-peer:
destination-pattern 444.
OK, you do have one DP for the match with 0 and another one without 0 after you strip it, correct???
java
Yes, on router 1 i have DP for the march with 0 and translation-profile to stripe 0 and send to trunk, where ona router 2 is DP without  0.
Please run basic debugs on both the routers, to see if call gets extended to Router 2.
debug ccsip messages
debug voip ccapi inout
debug vpm signal
/Amit
Jaime Valencia
This is Video Over IP, please move to a relevant area.
java
