Cisco 7960 SIP phone factory reset
ulambaday
Hi all,
  I have a 7960 SIP phone. I am trying to register to the CUCM so that I can convert it to SCCP.
But I am not able to get it registered because the default router and TFTP server still with old IP addresses.
Setting is not getting unlocked with **#.( I think this doesn't work for SIP phone)
I tried to do unlock config and tried password "cisco" but no luck . It is saying " invalid password"
Is there another way where I can get this phone registered to CUCM?
6 Replies 6
paolo bevilacqua
Search forum, or cisco.com and you will find the answer to your question.
I have same issue , any one can help ???
simon-leigh
Hold down the # key whilst plugging in the network cable. Keep holding the # key till the 'line' lights flash in sequence.
Once flashing release the # key and press 123456789*0#
This should work for you.
Paolo,
I searched in forum I tried but no luck
Simon,
           I tried that but it is still having the same old default router IP. I also tried to enter the default password  "Cisco" to unlock config but no luck
try reset sequence again.
If that doesn't work, configure a TFTP server with the address that phone look for. Feed it a configuration file that specified a new SCCP fimware like 7.x. That might have the phone update and then work normally.
simon-leigh
Did you resolve your issue?
