06-15-2015 12:26 PM - edited 03-17-2019 03:21 AM
Hi!
I have strip 0 (04441 -> 4441) from called number outgoing call. I have two routers connected via SIP Trunk. Each of the routers have FXS ports with attached analogue phones.
Config router 1:
voice translation-rule 1
rule 1 /^0\(.*\)/ /\1/
voice translation-profile 1
translate called 1
dial-peer voice 100 voip
voice translation-profile outgoing 1
destination-pattern 0444.
session target ipv4:192.168.10.2
Config router 2:
dial-peer voice 4441 pots
destination-pattern 4441
port 0/2/0
When I dial 04441 from router 1 I got busy tone. Phone on FXS 0/2/0 router 2 dont ring. What could be wrong?
Kamil
06-15-2015 01:10 PM
Hi Kamil,
Could you please share the topology.
Best regards,
Daniel Sobrinho
06-15-2015 02:15 PM
06-15-2015 03:59 PM
Have you properly updated the ip trusted list???
06-15-2015 04:05 PM
SIP Trunk working properly if I dont use translation-rules and change dial-peer:
destination-pattern 444.
06-15-2015 04:27 PM
OK, you do have one DP for the match with 0 and another one without 0 after you strip it, correct???
06-15-2015 04:33 PM
Yes, on router 1 i have DP for the march with 0 and translation-profile to stripe 0 and send to trunk, where ona router 2 is DP without 0.
06-15-2015 06:27 PM
Please run basic debugs on both the routers, to see if call gets extended to Router 2.
debug ccsip messages
debug voip ccapi inout
debug vpm signal
/Amit
06-15-2015 02:08 PM
This is Video Over IP, please move to a relevant area.
