problemas con llamadas entrantes router cisco 2821(problem with incoming calls cisco 2821)
jsotooplk
hi im having some problems when i try to do calls from an out source to the local numbers in my red, this not sounds,  its like we not do any call.
i check another configuration of this red and i note that this commands are left.
voice call carrier capacity active
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol cisco
voice class h323 10
voice class h323 1
  h225 timeout tcp establish 3
voice logout-profile 1
pin 9999
speed-dial 1 7000 label "7000"
voice-card 0
dspfarm
dsp services dspfarm
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 10
how can you hepl me with this?
Jaime Valencia
What's exactly the problem??
No audio?? one way audio?? phone doesn't ring???
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
El problema ocurre en que cuando se intentan realizar llamadas desde afuera hacia la red interna  desde numeros externos, las llamadas no repic, solo suena 2 tonos y se cae la llamada.
That the problem occurs when trying to make calls from outside to the internal network from external numbers, the calls does not ring, only sounds 2 beeps and drops the call.
I'd start by running some debugs on the router to confirm the calls are reaching it. If not, call telco.
java
java
