Problems incoming calls
We are having problems with incoming calls, when someone makes a call from the outside he can hear the tones but it doesn´t reach the internal phone. I have made a debug isdn q931 and it shows some errors that I don´t understand,
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A1080201480201008400
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0x00C3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '9xxxxxxxxx'
                Plan:ISDN, Type:National
*Sep 19 07:52:11.416: ISDN Se0/0/0:23 Q931: Received SETUP  callref = 0x9E88 cal
lID = 0x0046 switch = primary-5ess interface = User
*Sep 19 07:52:11.420: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x
9E88
*Sep 19 07:52:11.640: ISDN Se0/0/0:23 Q931: TX -> PROGRESS pd = 8  callref = 0x9E88
        Cause i = 0x8181 - Unallocated/unassigned number
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Sep 19 07:52:11.708: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8  callref = 0x1E88
        Cause i = 0x80E308 - Information element not implemented
        Call State i = 0x09
*Sep 19 07:52:21.496: ISDN Se0/0/0:23 **ERROR**: U7_ProgressReq: Sending PROGRESS in state 7 is not allowed. Dropping it
*Sep 19 07:52:21.496: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message forcall state 7, call id 0x46, call ref 0x9E88, event 0x89
*Sep 19 07:52:21.496: ISDN  **ERROR**: Module-l3_sdl_u  Function-Ux_BadMsg  Error-Source ID =  400  Event =  89
*Sep 19 07:52:31.140: ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 3
*Sep 19 07:52:31.140: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Calling num 9
*Sep 19 07:52:31.140: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x0117 callID = 0x8098 switch = primary-5ess interface = User
*Sep 19 07:52:31.140: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0117
                Standard = CCITT
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x21C3, '9'
        Called Party Number i = 0xA1, '498642949'
*Sep 19 07:52:31.260: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8117
        Cause i = 0x809C - Invalid number format (incomplete number)
*Sep 19 07:52:31.264: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x9E88
*Sep 19 07:52:31.360: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x1E88
*Sep 19 07:52:31.360: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9E88
Any help?
5 Replies 5
acampbell
Yor call is being received on the router but seems to be getting returned to the ISDN service CO.
Not sure about this original called number
May be you could show the config of the router.
Alex
Regards, Alex. Please rate useful posts.
cnuche
Can you please attache a CUCM detailed trace, the complete ISDN debug and the router config, also please attach a deb voice ccapi output.
seems that you are getting this from the TELCO
and that is causing the following:
Seems that this is a TELCO issue, but the traces will give us more info.
Christian Nuche
PDI Team.
This looks to be a dialplan problem.  Make sure that the you are hitting the dialpeers you are expecting to hit.
debug voice ccapi inout
debug isdn q931
Along with a config.
My guess is that you aren't matching dialpeers.
On the outbound call, you have the ISDN plan and type set to national, which means that you need to be careful on the digits that are sent based on the country you are in.
brunoserrano
It looks like a a dial plan or permision problem.
Make sure that the CSS of the gateway and the PT of the final Phone are correct.
Hi ,
this is the tarsilaation pattern problem please check with your transilation in cucm and incoming dial peer
