02-01-2011 06:30 AM - edited 03-16-2019 03:12 AM
We have a cluster with two CUCM servers System version: 6.1.4.1000-10.
I am trying to apply a Call Forward All from a Directory Number to a Hunt Pilot but it doesn't work, so I am applying the DN assigned to a Hunt Pilot in the destination field.
I think it's not a problem with CSS in Call Forward and Call Pickup Settings inside DN configuration web page.
Is this configuration a correct possibility?
If not, how could I implement a call forward all from one IP Phone with one DN to a set of several IP Phones?
Thanks in advance
02-01-2011 06:46 AM
Yes, that's supported and we also provide the CF no coverage field if you need special routing.
The only thing that could prevent that from working would be the CSS/partitions from CFA. Review them and make sure they're correct.
What happens if you dial that hunt pilot from the phone?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-01-2011 06:51 AM
Thanks for your quick answer,
If I call directly from IP Phone to Hunt Pilot it works!
Raúl Ferrero Ferreras
Systems Engineer
Dimension Data Spain
Plaza Cronos 1, Edif. Hansa Urbana III - Zona B 2ª planta, 28037 Madrid
Tel: +34 91 417 80 80
Fax: +34 91 417 80 81
raul.ferrero@eu.didata.com
For further information about Dimension Data, please go to www.dimensiondata.com
Antes de imprimir este mensaje, asegúrese de que es necesario. El medio ambiente está en nuestra mano.
02-01-2011 01:12 PM
Hi Raul,
Does it read on the IP phone display that the call has been forwarded to the hunt pilot DN? If it does then what do you hear when you dial the IP phone extension on which call forwarding is enabled?
Nitesh
02-01-2011 07:28 AM
Hi Raúl,
Like Java nicely noted (+5 Java)
Try setting the Call Forward CSS to the same level as the
phone CSS to allow CFWDALL to the Hunt Pilot DN.
Cheers!
Rob
