05-13-2010 07:53 AM - edited 03-15-2019 10:45 PM
Hi friends,
I have this doubt, when I reset a Cisco IOS Enhanced Conference Bridge by using the reset button in Conference Bridge configuration from my Call Manager 5.1.3. always I get an error in my voice gateway like this:
#sh sccp
Conferencing Oper State: DOWN_IN_PROGRESS - Cause Code: CCM_RESET_CMD
Active Call Manager: xxxx, Port Number: 2000
TCP Link Status: DISCONNECTING, Profile Identifier: 10
And this state remains indefinitely with no option until the gateway is resetted.
What I´m doing bad? Can I recover the conference bridge sccp state with no reset the voice gateway?
The gateway has MGCP conf but I´ve seen the same with H323.
Many thanks in advance to everyone.
Regards.
Pablo.
05-13-2010 08:30 AM
Pablo,
Have you tried "no sccp", "sccp"? Possibly an IOS bug?
Brandon
05-13-2010 09:01 AM
Many thanks Brandon for your quick response.
I´ve thought on that but in this way I also disconnect MTP and XCoding.
I´m facing this problem with the release c3825-advipservicesk9-mz.124-20.T2.bin but I saw the similar problem with the same Cisco IOS for another Cisco Routers models.
If you know this IOS bug please let me know.
Many thanks.
Pablo.
05-24-2010 07:15 PM
Hi there,
I got the same issue here with a 2801 running "c2801-advipservicesk9-mz.124-24.T1.bin" :
#show sccp
SCCP Admin State: DOWN
Gateway Local Interface: FastEthernet0/0.40
IPv4 Address: 10.1.50.1
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.1.130, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: DOWN_IN_PROGRESS - Cause Code: KEEPALIVE_FAILED
Active Call Manager: NONE
did you find the bug mentioned?
Thanks in advance for sharing your info with me man.
Roberto Bibian
05-25-2010 01:10 AM
Hi Roberto,
Unfortunately I´ve not found a related bug.
I´m pretty sure the matter is related to the IOS version. I had to reload the gateway because the state (in mi case) never return to Connected.
If you find the solution please let me know.
Really appreciated.
Pablo.
06-01-2010 12:55 PM
Hi Pablo,
Thanks for the reply. I had to reload the GW as well to re-register the HW CFB since it got stuck forever.
I'll certainly keep you posted if I find either a solution or at least an unresolved bug.
Bests,
RB
