Problems with HP Multifunction LaserJet
Morning all,
We have set up a VG224 for connectivity to existant Fax machines in one of our offices. These all work fine with the IPT envirment, however we are having big problems with HP LaserJet M1522NF Multifunction end points - these are the ones that print, scan, fax etc.
Problem is that the fax will just not answer. Has anyone seen this problem before, if so do you have a config work around as I cannot find anything on CCO or Google!
Cheers,
Carl
paolo bevilacqua
How long is loop (copper pair) betwen VG224 and fax machine ?
Hello there,
We tested this on a different cable which was within 100 metres and still had the same issue I am afraid.
Does a regular phone rings down that loop ?
