11-24-2011 11:59 AM - edited 03-16-2019 08:13 AM
I had to reinstall CMBE, I have a backup but I do not have the procedure to load into server.
any of you have this procedure? or any link I could check?
regards
11-24-2011 12:06 PM
The procedure to restore a BE is the same as for the CUCM. Please refer to:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/8_0_2/drsag802.html#wp63188
Tere.
If you find this post helpful, please rate!
11-24-2011 01:36 PM
Hi Tere,
I have already perform restore, but after some minutes of displaying progress reach 36 % there is a component (CDPAGT) where it taking too much time.. no more progress; is it normal??
regards
11-24-2011 12:14 PM
May be this link will help
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/8_0_1/drsag801.html
Alex
11-24-2011 02:22 PM
Hi alex,
The CMBE´s windows hangs after 36% progress in component (CDPAGT). I try to check the status with command
utils disaster_recovery status but I received the error " required 1 mandatory parameters but 0 parameters were found.
I don´t kow if I should stop de restore process, I want to be sure that the restore process is still running fine or definetly
something wrong happend
ragards
11-24-2011 02:29 PM
The command should be:
admin:utils disaster_recovery status restore
You should see something like this:
Tar Filename: 2010-01-21-10-00-00.tar Storage Location: NETWORK Operation: restore Percentage Complete: 90 CCM CUCM PLATFORM SUCCESS Sun Jan 24 20:37:18 EST 2010 /var/log/active/platform/drf/log/2010-01-24-20-37-09_r_cucm_ccm_platform.log CCM CUCM CDPAGT SUCCESS Sun Jan 24 20:37:23 EST 2010 /var/log/active/platform/drf/log/2010-01-24-20-37-09_r_cucm_ccm_cdpagt.log
Tere.
11-24-2011 02:35 PM
Hi tere,
we try to restore by GUI, but after 36% progress th GUI hangs and by CLI we could not check the progress.
we received the message" required 1 mandatory parameters but 0 parameters were found."
we are planning to try once but not selecting component (CDPAGT).
