Program a common number to dial a different destatination based on location
jason.loomans
Hi.  I haven't had to program this before.  I need to program a common number, say 8811, that dials a different destination based on your which building you are in.  What's the best practice for this?
paolo bevilacqua
Maybe mention product and version you're using ?
However, if that's CM, you would use partitions and CSS translations to achieve this.
As with other "advanced" configs, it is recommendable you have a reputable consultant, or Cisco Certified Partner to do it.
jason.loomans
I apologize.  Using CM 8.5.1 SU2.
Then as Paolo nicely mentioned all you need are partitions/CSS and translation patterns so that each location reaches a different DN after dialing 8811.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
