Properly remove MGCP
Limitless1801
  I am in the process of converting my MGCPs gateways to H323 and I am looking an easy way to remove the MGCP from the router other than using the "no" commando.
  Any ideas? Thanks.
Logan Gaffney
The only way to stop the MGCP service from running on the gateway is to issue the "no mgcp" command.
Be aware that you will have to remove the back haul config from the serial interface as well ("no isdn bind-l3 ccm"), as well as the mgcp controlled PRI.
All are service affecting
Please rate helpful posts!
-Logan
