03-04-2013 11:16 AM - edited 03-16-2019 04:03 PM
I took a look on :
which protocol is the best to put it work in a Gw? for this case...
https://supportforums.cisco.com/message/1144860#1144860
"For PSTN connectivity:
PRI is the best. You will have the least amount of troubles.
QSIG is a close secondary, and you get some more features, but it becomes a little harder to troubleshoot.
T1/E1 CAS should be avoided unless it's the only choice."
Why T1/E1 CAS should be avoided ?
It's my only choice.
Thanks.
Rosa
Solved! Go to Solution.
03-04-2013 11:47 AM
That answer depends on the point of view of each individual and from where they're from, in some countries you simply do not have the same choices and have to go with whatever is available.
AFAIK CAS was the old technology, and then most countries upgraded to PRI.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
03-04-2013 12:55 PM
Hi Rosa,
It depends... T1/E1 CAS is not bad just is the oldest tecnology so why request a Pentium III when you can have a Pentium i5 (I hope Intel send me a gift for the ad ).
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
03-04-2013 03:23 PM
Rosa,
SIP trunking is the next generation PSTN connectivity and is available in most markets these days via traditional telco carriers or new carriers. Basically rather than having TDM based circuit such as E1 or T1, you use either existing data connection or dedicated data connection to carry voice calls to PSTN provider via IP across a SIP trunk. The technology has been around for few years and has gained much of market share across the world. There are many benefits to it, and provider can list those to you along with ROI calculations.
HTH,
Chris
03-04-2013 03:45 PM
H323 or SIP between GW and CUCM. SIP is not just for SIP trunking, but it can also be used as GW control protocol.
MGCP does not support E1-CAS, so that is not an option, neither would I ever recommend MGCP for anything :-)
HTH,
Chris
03-04-2013 04:12 PM
Yes, you can configure the GW with SIP protocol, i.e. dial-peers and build it in CUCM as SIP trunk, this is very similar to building an H323 GW.
Both H323 and SIP are acceptable and it is just a matter of preference, you can easily convert H323 to SIP in future date if you bring in a SIP trunk instead of E1 R2 circuit.
Chris
03-04-2013 11:47 AM
java
03-04-2013 12:40 PM
Thanks for you answer.
In Brazil we have E1 R2 digital. Is it difficult to configure and troubleshoot ?
Rosa
03-04-2013 12:55 PM
Hi Rosa,
03-04-2013 01:31 PM
Or you can go for the i7 and get SIP trunk :-)
Chris
03-04-2013 03:19 PM
Oooops!
and now ? what are the benefits of choosing SIP trunk ? Can I have a Sip trunk to PSTN ?
i5 or i7 ?
Rosa
03-04-2013 03:23 PM
Rosa,
HTH,
Chris
03-04-2013 03:41 PM
I understand, but by now there is no choice as an E1 R2 digital is in use.
So H323 GW should be configured in order to accomplish compatibility with this E1 R2.
Thanks for your answer.
Rosa
03-04-2013 03:45 PM
HTH,
Chris
03-04-2013 04:08 PM
Chris I guess I misunderstood.
I can configure 2811 as SIP GW to interact with CUCM using E1 R2 ?
I am not able to figure out wich choice seems better and/or easiest to a novice.
If I prefer a H323 GW it will be possible, in the future, to change from E1 R2 to SIP trunk without reconfiguring 2811 ?
Thanks Rosa
03-04-2013 04:12 PM
Chris
03-04-2013 04:24 PM
Thanks.
I will continue configuring 2811 as H323 GW and after deployment is completed and service is stable changes could be done if necessary.
Rosa
