PSTN Failover not working with 2 SIP Trunks in Line Group
david.vanherck
I'm setting up a system: 3 CUCM servers (2 on Site A, 1 on Site B). On both sites A & B I have a 2921 Voice Gateway, connected to ISDN with 1 PRI. The Voice Gateways are controlled via SIP Trunks.
I want to set up failover to PSTN: if Voice Gateway on site A goes down, site B should be handling all voice calls. And vice versa: site B goes down, site A will be used for ISDN access.
If I create a Route Group with both Voice Gateways in it and the first one in line (using Top Down algorithm) goes down, then the calls to PSTN fail. If I force the other Voice Gateway as first one in the Route Group, then calls go to PSTN!
I tried also to create a Route Group with only 1 Voice Gateway in it and configured a Route List with 2 Route Groups in it (so Route Group for site A and Route Group for site B), but the same result: if the first one in line is not reachable, then calls fail.
Any idea why? SIP timers?
In normal conditions all PSTN calls are working.
Greets,
David
Chris Deren
Please set the following service parameters to FALSE:
Stop   Routing on Unallocated Number Flag
Stop   Routing on User Busy Flag
HTH,
Chris
Chris Deren
HTH,
Chris
Hi Chris,
Yes, this did the trick! :-) Many thanks!!! I was or SIP settings or this :-)
Cheers!
David
