PVDM Issue !!!!
hi all,
Can i use 2821 PVDM on cisco 3845.. reply urgent please .... or what the hardware paramters i should consider before shift PVDM from 2821 to 3845
dezoconnor
Level 4
Level 4
Hi, if you're talking about the PVDM2-8's, PVDM2-16's, PVDM2-32's & PVDM2-64's then yes you can use in any ISR router.
The PVDM2 DSPS (TI 5510) will work in any ISR the same way. They are the same DSPs that are in the VG202/4, VG224, 1861/UC520, and a number of other platforms as well.
-nick
