08-21-2008 07:49 AM - edited 03-15-2019 12:46 PM
All,
I have a SIP trunk between CUCM 5.1 and a CME site over MPLS. I have a priority queue setup for traffic that is marked as EF. When I watch traffice between the CUCM and CME I see the conneciton for the SIP trunk but there is no markings for the VOIP call. Because the traffic is not being marked the calls are not using QOS. If I watch a call here in my local office I see the traffic marked between 2 phones. How can I mark the traffic from my call manager to the CME as EF? Will it hurt of help if I add something like mls qos trust to the call manager ports on the switch?
08-21-2008 08:04 AM
The best practice is to mark as close as possible to the source. That means you should mark and on the swicth and then classify the marked traffic on the routers.
mls qos is used to enable qos on the switch.
Usually cisco IP Phones have their traffic marked by default, so you will just need to ocnfigure the switch to trust the marked traffic from the ip phones..
HTH, pls rate useful posts
08-21-2008 08:17 AM
The traffic from the IP phone is being marked. When I sniff the traffic I am not seeing the traffic from the phone but from the Call manager to the CME over the SIP trunk. This is the traffic that is not being tagged.
08-21-2008 09:12 AM
If the traffic from the IP Phone has been marked and qos is enabled on the switch, the ip phone traffic over the sip trunk should be marked too..IS QOS enabled on your switch?
08-21-2008 09:45 AM
Here is how my switchports and QOS are setup. I have also put the port for call manager here.
interface GigabitEthernet5/2
switchport access vlan 10
switchport mode access
switchport voice vlan 100
qos trust device cisco-phone
qos trust cos
auto qos voip cisco-phone
tx-queue 3
bandwidth percent 33
priority high
shape percent 33
spanning-tree portfast
spanning-tree bpduguard enable
service-policy output autoqos-voip-policy
qos dbl
qos map dscp 24 25 26 27 28 29 30 31 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
qos
interface GigabitEthernet3/9
description Call Manager
switchport access vlan 3
no cdp enable
When I sniff the traffic from the switch to my router I do not see traffic from the phone. I am seeing traffic from my call manager to the CME over the SIP trunk and it has no dscp marking.
08-21-2008 10:44 AM
on the switch ports for the CCM and routers etc add
mls qos trust DSCP
08-21-2008 10:44 AM
Do you have the appriopriate policy-maps and service-policy applied in the right direction on your router
08-21-2008 10:49 AM
Here is my policy-maps and serivice policy
class-map match-all VoIP-RTP
match ip dscp ef
class-map match-all VOIP-Cntrl
match ip dscp af31
match ip dscp cs3
policy-map Voice_wan
class VOIP-Cntrl
bandwidth 256
set dscp af31
class VoIP-RTP
priority 450
set dscp ef
class class-default
fair-queue
random-detect
policy-map MPLS-Sub
class class-default
shape average percent 75
service-policy Voice_wan
applied to
interface Multilink123
description MPLS
ip address
ip route-cache flow
load-interval 60
ppp chap hostname
ppp multilink
ppp multilink fragment disable
ppp multilink links minimum 1
ppp multilink group 123
service-policy output Voice_wan
08-21-2008 10:59 AM
I assume that your virtual multilink interface has been assigned to a pysical interface...
WHen you place calls between ccm and ccme, do you see the traffic matching the policies defined ont he interface..
\you can use the command.sh policy-map interface..command
08-21-2008 11:02 AM
Nope, that is how this all started. I was looking at the sh policy-map int and could see my queues not being used. then I started to sniff and could not see any markings coming from the call manager.
10-29-2008 07:37 AM
I'm not sure if you ever figured this out, but you won't see anything marked from your CCM. If you would like to see CCM packets being marked, make sure you have SCCP/SIP in your access-group. Voice packets never come from your CCM. Your CCM only sets up the call, after that the call is point to point.
10-29-2008 08:24 AM
But if it's a SIP trunk, the calls would go through that Trunk and you should be able to monitor that traffic correct? CUCM will setup the call between two end points, but if goes through a trunk on CUCM, then the packets should be seen correct?
