qos trust boundary
Ken Hagen
I need to configure several switches to trust dscp of PCs that are configured with various dscp markings for softphone applications.  The command I was given was mls qos trust.  The switches I have do not have that command.  I need to also trust the Cisco phones that will be connected.  Upon some research it appears I need to configure "switchport priority extend trust".  With that command it appears that the devices on the port are trusted.  I try to also configure "qos trust device cisco-phone", but the output for that is not what I expected.  Can someone explain?  I want to trust both cisco phone and softphone markings.  See below:
switch(config-if)#switchport priority extend trust
switch(config-if)#do sh run int g3/13
Building configuration...
Current configuration : 926 bytes
interface GigabitEthernet3/13
description x
switchport access vlan x
switchport mode access
switchport voice vlan x
qos trust extend
spanning-tree portfast edge
end
switch(config-if)#do sh qos int g3/13
Operational Port Trust State: Trusted
Trust device: none
Default DSCP: 0 Default CoS: 0
Appliance trust: trusted
switch(config-if)#qos trust device ?
cisco-phone Cisco IP Phone
cts Cisco-telepresence
ip-camera Cisco video surveillance camera
media-player Cisco Digital Media Player
switch(config-if)#qos trust device cisco-phone ?
<cr>
CSW-SMT-14-ACC(config-if)#do sh qos int g3/13
Operational Port Trust State: Untrusted
Trust device: cisco-phone
KEN HAGEN CCIE#56460
SENIOR NETWORK ENGINEER | PSA
SEATTLE CITY LIGHT
M: 206-459-0027 | ken.hagen@seattle.gov
We Power Seattle seattle.gov/city-light
Ken Hagen
Found the answer to my own question. Reason is because I do not have a cisco phone connected.
SEATTLE CITY LIGHT
Ken Hagen
SEATTLE CITY LIGHT
Glad you got this “resolved”.
Never even contemplated that you would not have a phone connected when you looked at the trust status for a port that is set to trust a phone if it’s connected, as that would in a scene defeat the intent of the command as such.
Isn’t it somewhat obvious that this would be the outcome of this specific show command with your criteria’s in mind?
Response Signature
We have softphones. Many people are not at work and don't need a phone on their desk. I was trying to be pro-active in case a phone was ever installed at the location in the future.  Although we do have some non-cisco voip phones that are being swapped out for cisco phones which throws another variable into it, but mostly softphones. Thanks for your comment.
SEATTLE CITY LIGHT
