qsig trunk
tkavithas87
i am integrating cisco cme with nec pbx.
can able to call from cisco to  nec pbx.but couldnt call from nec pbx to cisco.see the debug when call  made from nec to cisco.
cme#debug isdn error
cme#
052409: Sep 20 23:33:25.351: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
what could be the reason?
You never get a match for an outgoing dial peer. Best bet for why is your voice translation rule that you have attached to dial peer 6, since that dial peer seem to be used in the incoming direction.
Please rate useful posts.
Response Signature
8 Replies 8
Mark Turpin
Level 5
Level 5
Can you please upload your config so we can review?  The error you have listed is a cosmetic issue I believe and is not likely causing the problem.
Also, can you turn on a debug isdn q931
Then try your call and make sure you upload that debug!
Thanks!
-Mark Turpin
-Mark Turpin
CALLING FROM NEC PBX TO CISCO
CME#debug isdn q931
debug isdn q931 is              ON.
UC560#
052455: Sep 21 17:41:29.674: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0036
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0081, '200'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x81, '4003'
                Plan:ISDN, Type:Unknown
        Low Layer Compat i = 0x8090A3
        High Layer Compat i = 0x9181
052456: Sep 21 17:41:29.678: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8036
052457: Sep 21 17:41:29.682: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8036
        Cause i = 0x829C - Invalid number format (incomplete number)
052458: Sep 21 17:41:29.766: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0036
        Cause i = 0x8090 - Normal call clearing
052459: Sep 21 17:41:29.766: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8036
cme#sh running-config
Building configuration...
Current configuration : 27438 bytes
! Last configuration change at 10:38:40 PST Fri Sep 21 2012 by cisco
! NVRAM config last updated at 10:38:43 PST Fri Sep 21 2012 by cisco
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC560
boot-start-marker
boot-end-marker
card type e1 0 2
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone PST -8 0
clock summer-time PST recurring
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
crypto pki trustpoint TP-self-signed-2705201232
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2705201232
revocation-check none
rsakeypair TP-self-signed-2705201232
crypto pki certificate chain TP-self-signed-2705201232
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373035 32303132 3332301E 170D3132 30393137 30303539
  34315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37303532
  30313233 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD97 03DEBC1A 58C334A7 ED7193AD 0E9F89AE 98647A81 541992BE 2E2B5215
  DB76CE7F E5F97426 85D81D5B C89943F0 941A2A71 5491A8B1 ED0DF089 321DFF2E
  D2A31920 E2F24CF9 56C40B31 6EAE7E06 6B16A936 639400EF C2FE9CED BAE11CDD
  729516C0 53676D1E 6E6A2DE7 EAB47D89 D241F584 C264F4ED 401C8C51 359C245D
  2EA30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14827485 770F63C4 F34106F2 709FBEC2 CA3C4177 CC301D06
  03551D0E 04160414 82748577 0F63C4F3 4106F270 9FBEC2CA 3C4177CC 300D0609
  2A864886 F70D0101 05050003 81810012 7BF7C0B1 39EE1799 B8659B2E 484C5B1D
  6726D085 58449D1E AA967D32 1CB4B69B A67017D3 EA00FEE0 277FA239 C6842DBF
  FAD2220E 2094949D AD1D02FF 89622EDB F4DA4BCC 71A8095A 1994C4DD 285401C9
  C6E51AB2 541AFEC5 E93EB464 80D408D9 2796332E 2716132E 198D431C C6518D5E
  D94CF780 064848B8 798C7636 464EF9
        quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-qsig
voice call send-alert
voice rtp send-recv
voice service voip
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 50
max-pool 10
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
voice register pool  1
voice translation-rule 1000
rule 1 /.*/ //
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC560-FXO-K9 sn FGL163610PM
archive
log config
  logging enable
  logging size 600
  hidekeys
username cisco privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
controller E1 0/2/0
pri-group timeslots 1-31
ip tftp source-interface Vlan90
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application module
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport mode trunk
switchport voice vlan 100
no ip address
macro description cisco-switch
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
macro description cisco-desktop
spanning-tree portfast
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
no ip address
interface Serial0/2/0:15
no ip address
encapsulation ppp
isdn timer T310 120000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Vlan1
description $FW_INSIDE$
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Vlan90
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp any 10.1.10.0 0.0.0.3 range 16384 32767
access-list 103 permit udp 10.1.10.0 0.0.0.3 range 16384 32767 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
timeouts ringing infinity
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/2/0:15
voice-port 0/1/0
connection plar 803
caller-id enable
voice-port 0/1/1
connection plar 802
caller-id enable
voice-port 0/1/2
connection plar 203
caller-id enable
voice-port 0/1/3
connection plar 204
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
destination-pattern 0[689].......
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
no sip-register
dial-peer voice 52 pots
port 0/1/2
no sip-register
dial-peer voice 53 pots
port 0/1/3
no sip-register
dial-peer voice 55 pots
destination-pattern [2]..
incoming called-number ....
direct-inward-dial
port 0/2/0:15
dial-peer voice 57 pots
no dial-peer outbound status-check pots
telephony-service
video
authentication credential cisco cisco
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message UC560
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.9-2-1S
load 7911 SCCP11.9-2-1S
load 7921 CP7921G-1.4.1SR1
load 7925 CP7925G-1.4.1SR1
load 7931 SCCP31.9-1-1SR1S
load 7936 cmterm_7936.3-3-21-0
load 7937 apps37sccp.1-4-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.9-1-1SR1S
load 7941GE SCCP41.9-1-1SR1S
load 7942 SCCP42.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7961GE SCCP41.9-1-1SR1S
load 7962 SCCP42.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 7970 SCCP70.9-1-1SR1S
load 7971 SCCP70.9-1-1SR1S
load 7975 SCCP75.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-9c
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 525G2 spa525g-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
load 6921 SCCP69xx.9-1-1-2-sr
load 6941 SCCP69xx.9-1-1-2-sr
load 6961 SCCP69xx.9-1-1-2-sr
load 6901 SCCP6901.9-1-1-0
load 6911 SCCP6911.9-1-1-0
time-zone 5
keepalive 30 auxiliary 4
voicemail 2000
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$vm91$LWEnaguUjGJ8OJmSFN0IA.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Sep 17 2012 20:30:37
ephone-template  15
button-layout 7931 2
ephone-dn  1  dual-line
number 4001
ephone-dn  7  dual-line
number 4002
ephone-dn  8  dual-line
number 4003
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 4004
ephone-dn  11  dual-line
number 4005
ephone  1
device-security-mode none
mac-address 64D8.14A5.9210
max-calls-per-button 2
type 7975
button  1:1
ephone  2
mac-address B03D.5B02.2001
type anl
ephone  3
mac-address B03D.5B02.2002
type anl
ephone  4
mac-address B03D.5B02.2003
type anl
ephone  5
mac-address 7081.053E.1FFF
type 509G
ephone  6
mac-address B03D.5B02.2000
type anl
ephone  7
mac-address A456.3041.A75C
type 7941
button  1:7
ephone  8
mac-address 30E4.DB80.41D7
type 508G
button  1:8
ephone  10
mac-address C89C.1D6D.850B
type 502G
button  1:10
ephone  11
mac-address 0CD9.9690.7611
type 7965
button  1:11
ephone  12
banner login ^CUC500 Base Config - Default 8.6.0 ^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
Thanks, can you also take a 'debug voip dialpeer all' and 'debug voice translation' and place another call and then upload the results?
-Mark Turpin
-Mark Turpin
thank you so much mark turpin for the reply
cme#debug voip dialpeer all
voip dialpeer all debugging is on
cme#
052460: Sep 21 18:12:02.658: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0037
                Standard = CCITT
052461: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=200, Called Number=4003, Voice-Interface=0x8AA61214,
   Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
052462: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=4003
052463: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
052464: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=4003, Expanded String=4003, Calling Number=
   Timeout=FALSE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
052465: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=6 Is Matched
052466: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=55 Is Matched
052467: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
052468: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=6
052469: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
052470: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6564
052471: Sep 21 18:12:02.658: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=200, Called Number=4003, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
052472: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
052473: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
052474: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Timeout=FALSE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_FAX
052475: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=1,Peer Info Type=DIALPEER_INFO_SPEECH)
052476: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=2,Peer Info Type=DIALPEER_INFO_SPEECH)
052477: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3,Peer Info Type=DIALPEER_INFO_SPEECH)
052478: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=4,Peer Info Type=DIALPEER_INFO_SPEECH)
052479: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=5,Peer Info Type=DIALPEER_INFO_SPEECH)
052480: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=6,Peer Info Type=DIALPEER_INFO_SPEECH)
052481: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=50,Peer Info Type=DIALPEER_INFO_SPEECH)
052482: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=20001,Peer Info Type=DIALPEER_INFO_SPEECH)
052483: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=20002,Peer Info Type=DIALPEER_INFO_SPEECH)
052484: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=20004,Peer Info Type=DIALPEER_INFO_SPEECH)
052485: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=20006,Peer Info Type=DIALPEER_INFO_SPEECH)
052486: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=20008,Peer Info Type=DIALPEER_INFO_SPEECH)
052487: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=20009,Peer Info Type=DIALPEER_INFO_SPEECH)
052488: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=55,Peer Info Type=DIALPEER_INFO_SPEECH)
052489: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
052490: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
052491: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=200
052492: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
052493: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=200T
052494: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052495: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052496: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052497: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052498: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052499: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052500: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052501: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052502: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052503: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052504: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052505: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052506: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052507: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052508: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
052509: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
052510: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=200
052511: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
052512: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
052513: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052514: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052515: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052516: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052517: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052518: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052519: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052520: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052521: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052522: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052523: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052524: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052525: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052526: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
052527: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
052528: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
052529: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
052530: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
052531: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6564
052532: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
052533: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
052534: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
052535: Sep 21 18:12:02.662: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
052536: Sep 21 18:12:02.666: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8037
052537: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4003, Peer Info Type=DIALPEER_INFO_SPEECH
052538: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=4003
052539: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
052540: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20006 Is Matched
052541: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
052542: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=4003, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
052543: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20006
052544: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchPeersCore:
052545: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchPeersCore:
052546: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchSafModulePlugin:
   dialstring=, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
052547: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
052548: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchPeersCore:
052549: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchPeersCore:
052550: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchSafModulePlugin:
052551: Sep 21 18:12:02.666: //-1/AD6EBF3F8035/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
052552: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
052553: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
052554: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
052555: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
052556: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
052557: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
052558: Sep 21 18:12:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
052559: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
052560: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
052561: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
052562: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
052563: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
052564: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
052565: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
052566: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
052567: Sep 21 18:12:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
052568: Sep 21 18:12:02.670: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8037
052569: Sep 21 18:12:02.754: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0037
052570: Sep 21 18:12:02.754: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8037
thanks & regards
kavi
Can you please delete or shutdown dial peer 6 and try again with the debugs turned on?
-Mark Turpin
Response Signature
thanks mark,roger.
i removed dialpeer 6.now its working
