Query about cucm ict
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-07-2014 06:55 AM - edited 03-16-2019 10:03 PM
HI We have 2 cluster in different countries for CUCM ( One for APAC one for UK ) which are connected through ICT . Is it possible if a cisco phone at APAC CAN HAVE A SECONDARY LINE FOR UK “ I tried the same but APAC publisher only showing APAC partition and not any partition for UK . Can someone Please let me know if this is Possible . Thanks RJ
- Labels:
CUCM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-07-2014 07:26 AM
Hello Ravi,
What do you mean by the secondary line for UK?
What's the exact requirement?
Sent from Cisco Technical Support Android App
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-07-2014 07:32 AM
Cisco Phone( 7960) in APAC has 1st line configured as 1111 , this phone placed in APAC ONLY .. we want 2nd line on this phone should be of UK number e.g . 2222
We Have 2 Cluster .. APAC ( dial-plan range - 1XXX) UK ( Dial-plan range 2XXX)
both of these cluster are connected thrugh ICT ..
So we want 2nd Line on APAC phone as UK number .. Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-07-2014 07:57 AM
Assign the DN to the phone and just configure the routing from the UK cluster to direct calls to 2222 via the ICT.
If you mean you want to have line 2222 registered to the UK cluster, while having 1111 registred in APAC, that's impossible.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-07-2014 07:54 AM
You can create the partitions for UK numbers in APAC cluster.
Don't you want the calls to over ICT for UK numbers ?
