"Not enough bandwith" problems
Walter Maciola
i have some problems with  "Not enough bandwith" error message on some device pools.
Allthough there is enough bandwith allocated in System -> Locations.
Is there any possibility where i can monitor the cac consumption of certain device pools.
Any hints?
Walter
acampbell
Use RTMT
System --> Performance ---> Pick the Server you want to monitor
---> Cisco LOcations ---> Choose Locations you want to monitor
---> Bandwidth Available
The graph should change as the usage rises & falls
Hth
Alex
Regards, Alex. Please rate useful posts.
5 Replies 5
acampbell
Use RTMT
Hth
Alex
Hello Alex,
Great. Just for this i was looking for.
Many thanks.
Walter
are you using UCM version 7.1.x?
7.1.5
walter, this is a known bug with this version as of 7.1.3. Contact Cisco, they will tell you about.  We had this problem as well.
