Router (A) can not take any call from outside (any IP and Router B - not registerd to any gatekeeper) when it is registered on gatekeeper . When Router B tries to establish a "plar" connection, I see RRJ messages in GnuGK logs to Router B. Why? How can I exclude certain prefixes (73952......, 3359670 & 2408650) from RAS? If i issue a no gateway command on router A - connection Plar begins to work. And router accepts call from IP to POTS. Why Router a asks a gatekeeper to accept an incoming call? Thank you.
Router A
interface Dialer0
h323-gateway voip interface
h323-gateway voip id Atelye ipaddr 188.128.xx.xx 1719
h323-gateway voip h323-id myro01
voice-port 1/0/1
connection plar opx 2408651
description 73952240865; SibirTC
voice-port 1/1/0
description 73952241076; SibirTC
dial-peer voice 3359670 pots
destination-pattern 3359670
port 1/0/0
dial-peer voice 2408650 pots
destination-pattern 2408650
port 1/0/1
dial-peer voice 73952 pots
destination-pattern 73952......
port 1/0/2
port 1/0/3
dial-peer voice 3359671 voip
destination-pattern 3359671
modem passthrough nse codec g711alaw
session target ipv4:192.168.26.254
dtmf-relay h245-signal
codec g729r8 bytes 40
fax-relay ecm disable
fax rate 9600
fax protocol t38 nse force ls-redundancy 1 hs-redundancy 1 fallback pass-through g711alaw
no vad
dial-peer voice 2408651 voip
destination-pattern 2408651
fax rate 9600
no vad
dial-peer voice 985 voip
description GK.ATELYE.NET
destination-pattern [0,9]8.T
voice-class codec 1
session target ras
dtmf-relay h245-alphanumeric
fax rate 9600
fax protocol t38 nse force ls-redundancy 2 hs-redundancy 2 fallback pass-through g711alaw
no vad
gateway
Router B:
voice-port 1/0
connection plar 3359670
description PLAR To ts; 335967
voice-port 1/1
connection plar 2408650
description PLAR To ts; 240865
dial-peer voice 3359671 pots
port 1/0
no register e164
dial-peer voice 2408651 pots
port 1/1
no register e164
dial-peer voice 3359670 voip
session target ipv4:192.168.99.254
fax rate 9600
no vad
dial-peer voice 2408650 voip
fax rate 9600
no vad
dial-peer voice 983952 voip
description Irkutsk City numbers for FAXing
destination-pattern 73952[1,2,3,4,5,6,7,9].....
fax rate 9600
no vad
