RDP Template BAT
anish.gupta11
I have created the Remote Destination Profile Template and added line template. I have just added provided line template name, partition, EPNM and partition in Add A New DN. However, when i run the BAT it updates the existing DN i.e. makes description,alerting name, CSS, VM profile to blank. Is there a way to update the existing DN from the template. Or am i missing some config. here.
Thanks and Regards!!
Jaime Valencia
Yes, profiles are meant to be used when you're adding new RDPs, not to update
Create remote destination profile template
You can create a template to add remote destination profiles in bulk.
java
if this helps, please rate
Hi Jaime,
Thanks for your response. I have already deployed the UDP's and DN's. But now customer wants to create RDP for more than 600 users. So how to associate the RDP with existing UDP directory number.
