IP Telephony and Phones
Labels
Is it possible to get any CUCM Hunt Group information out of SNMP?  I'm trying to come up with a quick and dirty method to see which extensions are currently logged in to a HG.  I don't see anything by browsing the MIB and I don't believe this is pos...
DougW1215 by Beginner
  • 121 Views
  • 1 replies
Hi All, I have found that users are unable to dial certain UK mobile numbers which begin 073. In the past we have added specific route patterns for these and they worked. I tried adding the following route pattern pointing to the relevant GW etc.. 9...
GRANT3779 by Frequent Contributor
  • 446 Views
  • 12 replies
I am running CUCM 10.5.2.   I have configured a Call Pickup and added a few people into it and am able to pickup calls to this group from any other person within the group. The problem is that I want to pickup calls to this group from someone outsi...
mcgeehonjp by Beginner
  • 3479 Views
  • 1 replies
Hello all, We need to upgrade our 3845 ISR cube routers to the 3945 ISR cube routers since the 3845 will no longer be eligible for support later this year.  Can anyone here on the forums tell me if the PVDM2-64 modules can be re-used on the 3945 ISR...
Hi, I'm working on SIP trunk configuration in CUCM 9.5. I want to modify the SIP timer values for a specific trunk. However, to my knowledge the change in timers is cluster wide and for all trunks. So is there a way to alter these values for a specif...
tcnagpure1 by Beginner
  • 2129 Views
  • 3 replies
