Re-registration timeout not working on SIP Trunk to ITSP
metalium2007
Level 3
Level 3
I'm currently configuring a sip trunk to an ITSP with sucess. The only problem is that the registration expiration timer sent from the ITSP are 180 seconds and even if i change that value in my configuration I always send the re-registration request only after 240 secs.
sip-ua
credentials username <user> password 7 <pass> realm <realm>
authentication username <user>password 7 <pass>
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:xx.yy.zz.ww expires 180
sip-server ipv4:xx.yy.zz.ww
host-registrar
show sip-ua register status
Line                                            peer         expires(sec)   registered           P-Associ-URI
<my_reg_number                        20007           229             yes
_____________________________________________
(C2800NM-ADVENTERPRISEK9-M), Version 15.1(1)T
Do you have any hint about this parameter changing? some bug or wrong config?
Thank you!
met
dksingh
Hmm...not sure what version of IOS you have but
please check if you can configure following...
sip-ua
  registrar  ipv4:xx.yy.zz.ww expires 180 refresh-ratio 50
with this IOS will send the reg refresh at 90 sec...
Curious, why we are negotiating 240 sec when we are configured
for 180sec? Did u run ccsip mess debugs on IOS and check
Expires field in the Reg and Ack msgs ?
HTH,
DK
