12-03-2009 09:06 AM - edited 03-15-2019 08:39 PM
Has anyone succeeded in being able to configure CM to provide a realtime analog output of a IP phone conversation to a recording system that only accepts analog inputs?
I have looked at documentation till I'm blue in the face and not found anything. Is there a third party product that would interface between the two?
This is a police department and there are at least 5 extensions that need to be monitored.
12-07-2009 10:24 PM
Mmm IP Phone means IP network, packets, so somehow you need a converter that tramsit that info to those lines.
I think they can help you:
03-20-2021 10:10 AM
Hello;
did you figure it out?! Am facing the same problem. Advice please
regards
