Reception Hunt Pilot transfer to MeetMe Number disconnects
Chadster766
Reception Hunt Pilot transfer to MeetMe Number disconnects.
Call Flow:
FXO Line => CTI 6000 => CUC Call Handle 6000 => Digit 0 => Call Handler 4505 => Transfer Rule (STD) => Hunt Pilot 4505 => Reception Answers DN 4000-4005 (Longest Idle Time) => Transfer to MeetMe DN 5550
Can the receptionist start the meete? This would confirm proper partition/CSS issue.
What codec is the conference bridge using? Might be codec negotiation issue, reviewing CM trace files would reveal this or any other cause.
9 Replies 9
Chris Deren
Is MeetMe already started? Remember to join meetMe bridges you first need to open it by pressing the Meetme softkey on a phone.
Yes testing was done with the MeetMe conference started before reception transfer to 5550.
The receptionist can create the MeetMe but as soon as she transfers one of the 4000-4005 DN to the MeetMe DN they get disconnected.
I did more testing and all reception DN's can create the MeetMe conference.
I'd try a simpler test, call the reception directly, can she transfer the call to the meet-me DN?
What protocol are you using on the GW?
And just to be clear, someone else, not the receptionist, is the one who starts the meet-me and waits for the other participants to join??
java
if this helps, please rate
I'm using the Software CFB. Yes everyone can create and join a MeetMe conference the way I have it configure at the moment.
Just incoming FXO calls through the Call Handlers are being disconnected once transferred to the MeetMe.
OK, what protocol are you using on the GW with that FXO?
java
voice service voip
 ip address trusted list
  ipv4 172.27.199.11
  ipv4 172.27.199.14
  ipv4 172.27.199.15
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 no fax-relay sg3-to-g3
 modem passthrough nse codec g711ulaw
 sip
  bind control source-interface BVI1
  bind media source-interface BVI1
  asymmetric payload full
  no update-callerid
voice class uri ucm sip
 host 172.27.199.11
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g711alaw
 codec preference 4 ilbc
I'm not sure this is below section is much help since I'm using the software CFB:
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp ccm 172.27.199.11 identifier 1 priority 1 version 7.0
sccp ccm group 1
 bind interface BVI1
 associate ccm 1 priority 1
 associate profile 1 register CFB1ARBORG
ccm-manager sccp local BVI1
dspfarm profile 1 conference
 description Arborg Conference Bridges
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g722-64
 codec ilbc
 maximum sessions 3
 associate application SCCP
It was codec mismatch between the Conference Bridge Device Pool and Gateway codex.
Thanks everyone for the support.
