07-24-2013 10:39 AM - edited 03-16-2019 06:32 PM
In most of our offices the receptionists use ARC to route calls but we have a small office opening and the office manager does not want to use ARC.
I would like the reception phone to be able to handle 4 or 5 lines so she can place calls on hold or transfer.
What is the best way to do this.
07-24-2013 10:42 AM
Are you using CUCM or CME? What model phones will the receptionist have?
Yosh
07-24-2013 10:59 AM
We are CUCM and she will have a 7975 or a 7945.
I don't think a 7945 would be the best choice
07-24-2013 11:13 AM
There are many ways to approach this.
Example 1:
Phone
Line 1 - 1000
CFWD Busy 1001
Busy Trigger 1
Line 2 - 1001
CFWD Busy 1002
Busy Trigger 1
Line 3 - 1002
CFWD Busy 1003
Busy Trigger 1
Line 4 - 1003
CFWD Busy 1004
Busy Trigger 1
Line 5 - 1004
CFWD Busy 1005
Busy Trigger 1
Line 6 - 1005
CFWD Busy 1006
Busy Trigger 1
Line 7 - 1006
CFWD Busy 1007
Busy Trigger 1
Line 8 - 1007
Example 2:
Line 1 - 1000
Busy Trigger 8
Yosh
