Redirecting CSS and Diversion Header
m8kubicki
Hi all,
I got a strange situation or maybe it works as disgned.
I've got a CUCM 8.6 SU2 running configured on the SIP trunk:
Redirecting Diversion Header Delivery - Outbound ==> ENABLED
Redirecting Party Transformation CSS ==> CSS_Redirect (Contains only redirect Partition with one Pattern)
Calling Party Transformation ![0-9#] -> 1234XXXX
What now happens if I do a normal call from a Cisco IP Phone over the SIP Trunk my redirecting/diversion header contains 1234XXXX (and the 4Xs contains the last 4 digits of the CALLED number)?!?
My questions now:
Why the diversion header is delivered for a normal call and why my Calling Party Transfromation matches the CALLED number?
Many Thanks in advance!
Marcel
Ayodeji Okanlawon
Most likely, the problem you are having is that you have "use device pool calling party transformation css" tickbox checked. Or you have configured a calling party transofrm css on the phone..Hence the phone us using the transformation css for internal phones
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
