Redundant call agent
alialjamri2008
I tried to configure redundant call agent with below configuration on the gateway (2951) but it fails:
ccm-manager redundant-host 192.168.50.11                           ---------------------------- Publisher
call-agent 192.168.50.12 2427 service-type mgcp version 0.1   ------------------------------Subscriber
Primery is Subscriber
Ali
12 Replies 12
Could you please describe the problem you see in more detail?
Please remember to rate all useful posts.
Response Signature
I am trying to configure the Subscriber as the primery call agent and the Publisher as secondry. But the things work while the call agent is the Subscriber (primery), however when the subscriber goes down the Publisher doesn't take over (with above configuration in place).
Ali
What do you get when you do a show ccm-manager?
Response Signature
Attached show ccm-manager,
Ali
You mean that when the sub is down then the calls not working right?
From the ccm-manager file it looks that is registered ok with the pub
Not working incoming outgoings calls?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Any calls through the gateway is not working (outside calls), only internal call is working.
Ali
In the CUCM is registered the MGCP GW right?
Try no mgcp and mgcp in voice gateway
Debug mgcp packets in VG
Can you send the mgcp config in VG?
attached the mgcp configuration
Ali
Is the PUB in the Call manager group fo
the device pool that the gateway is using ?
E.g.
CM-GROUP MYGROUP = SUB & PUB
Device Pool MGCP-GW
CM GROUP  --- MYGROUP
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Yes both Pub and Sub are on the call manager group and Device pool.
Ali
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager switchback immetiade
ccm-manager fallback-mgcp
mgcp
mgcp call-agent 192.168.50.12 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
After the registration in CUCM BIND here the voice interface for media and call control
mgcp bind control source-interface FastEthernet0/1.102
mgcp bind media source-interface FastEthernet0/1.102
interface Serial0/0/0:15 (if is E1)
isdn bind-l3 ccm-manager
After all the above . no mgcp and mgcp
From the output of your show ccm-manager it lookes like the pub is the one that is used as the call agent, not the sub.
sh ccm-manager
MGCP Domain Name: IABRTR
Priority        Status                   Host
Primary         None
First Backup    Registered               192.168.50.11
Second Backup   None
Current active Call Manager:    192.168.50.11
Please remember to rate helpful responses and identify helpful or correct answers.
Response Signature
