IP Communicator and USB Speakerphone
taylor.p
     I would like to know if there any USB speakerphones that integrate with CIPC V7?  I have recently purchased a Polycom CX100 , but it appears that the On-hook, Off hook and mute controls on that speakerphone do not work with CIPC. The volume controls work ok though...
I have used the Audio Tuning wizard to "tune" the speakerphone but this makes no difference to the controls as stated above.
So if any one out there knows a speakerphone that fully integrates I would appreciate knowing what it is..
Jonathan Schulenberg
The Jabra SPEAK 410 will assuming you have their PC Suite installed.
Supporting documentation (page 10):
http://www.jabra.com/~/media/Files/Guides/PM_BR_SOFTPHONEGUIDE_1201_V09_150DPI.ashx
Please remember to rate helpful responses and identify helpful or correct answers.
