refresh upgrade failed 11.5 to 12.5 cisco unity
lalitkumar88551
Hi please suggest.
tart Refresh Upgrade (yes/no): yes
The upgrade log is install_log_2021-12-23.11.19.16.log
Upgrading the system. Please wait...
12/23/2021 11:19:17 file_list.sh|Starting file_list.sh|<LVL::Info>
12/23/2021 11:19:17 file_list.sh|Parse argument method=local_dvd|<LVL::Debug>
12/23/2021 11:19:17 file_list.sh|Parse argument source_dir=|<LVL::Debug>
12/23/2021 11:19:17 file_list.sh|Parse argument dest_file=/var/log/install/downloaded_versions|<LVL::Debug>
12/23/2021 11:19:17 file_list.sh|is_upgrade_lock_available: Upgrade lock is available.|<LVL::Debug>
12/23/2021 11:19:17 file_list.sh|status in upgrade status.xml upgrade.stage.checksumming|<LVL::Debug>
12/23/2021 11:19:17 file_list.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 10786)|<LVL::Debug>
12/23/2021 11:19:17 file_list.sh|clear_upgrade_status: Status file removed|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|Parse argument fromVersion=11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|_set_upgrade_status_attribute: fromVersion set to 11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|Parse argument status=upgrade.stage.determining.files|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|_set_upgrade_status_attribute: status set to upgrade.stage.determining.files|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|Process local CD/DVD request|<LVL::Info>
12/23/2021 11:19:19 file_list.sh|Unmounting /mnt/source incase it is mounted|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|Mount /dev/cdrom on /mnt/source|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|iso image detected|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|List file (pre-filtered):|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|(CAPTURE) UCSInstall_CUC_12.5.1.15900-38.sgn.iso|<LVL::Debug>
12/23/2021 11:19:19 file_list.sh|/opt/cisco/install/bin/filter file=/var/log/install/downloaded_versions|<LVL::Debug>
12/23/2021 11:19:19 filter|Parse argument file=/var/log/install/downloaded_versions|<LVL::Debug>
12/23/2021 11:19:19 filter|No patch type specified. Optional.|<LVL::Debug>
12/23/2021 11:19:19 filter|No upgrade mode specifed. Optional.|<LVL::Debug>
12/23/2021 11:19:22 filter|Processing filter candidate names|<LVL::Debug>
12/23/2021 11:19:22 filter|Process "UCSInstall_CUC_12.5.1.15900-38.sgn.iso"|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (plm..*.cop)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (plm..*.cop.sgn)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (plm..*.cop.sha512)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against patch pattern (UCSInstall_UCOS_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against patch pattern (UCSInstall_UCOS_UNRST_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against patch pattern (UCSInstall_UCOS_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sgn.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against patch pattern (UCSInstall_UCOS_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sha512.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against patch pattern (UCSInstall_UCOS_UNRST_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sgn.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against patch pattern (UCSInstall_UCOS_UNRST_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sha512.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against es pattern (UCSInstall_UCOS_ES[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against es pattern (UCSInstall_UCOS_UNRST_ES[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against es pattern (UCSInstall_UCOS_ES[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sgn.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against es pattern (UCSInstall_UCOS_ES[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sha512.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against es pattern (UCSInstall_UCOS_UNRST_ES[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sgn.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against es pattern (UCSInstall_UCOS_UNRST_ES[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sha512.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against su pattern (UCSInstall_UCOS_SU[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against su pattern (UCSInstall_UCOS_UNRST_SU[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against su pattern (UCSInstall_UCOS_SU[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sgn.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against su pattern (UCSInstall_UCOS_SU[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sha512.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against su pattern (UCSInstall_UCOS_UNRST_SU[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sgn.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against su pattern (UCSInstall_UCOS_UNRST_SU[0-9]*_(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).sha512.iso)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (dp-ffr.[1-9]-[0-9]-[0-9]+.*.cop)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (dp-ffr.[1-9]-[0-9]-[0-9]+.*.cop.sgn)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (dp-ffr.[1-9]-[0-9]-[0-9]+.*.cop.sha512)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (cm-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (cm-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sgn)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (cm-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sha512)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (po-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (po-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sgn)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (po-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sha512)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (uc-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop)|<LVL::Debug>
12/23/2021 11:19:22 filter| Match against cop pattern (uc-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sgn)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (uc-locale-.*_.*-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sha512)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (uc-friendly-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (uc-friendly-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sgn)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (uc-friendly-(?:[0-9]|1[01].[0-9]+.[0-9]+.[0-9]+-[0-9]+).cop.sha512)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (ciscocm..*.cop)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (ciscocm..*.cop.sgn)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (ciscocm..*.cop.sha512)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (platform-csa-.*.cop)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (platform-csa-.*.cop.sgn)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (platform-csa-.*.cop.sha512)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (ucos..*.cop)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (ucos..*.cop.sgn)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against cop pattern (ucos..*.cop.sha512)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against patch pattern (UCSInstall_CUC_[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+-[0-9]+.iso)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against patch pattern (UCSInstall_CUC_UNRST_[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+-[0-9]+.iso)|<LVL::Debug>
12/23/2021 11:19:23 filter| Match against patch pattern (UCSInstall_CUC_[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+-[0-9]+.sgn.iso)|<LVL::Debug>
12/23/2021 11:19:23 filter|INorOUT=IN UCSInstall_CUC_12.5.1.15900-38.sgn.iso: Filter passed.|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|List file (post-filtered):|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|(CAPTURE) <?xml version="1.0" encoding="UTF-8"?>|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|(CAPTURE) <InstallList>|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|(CAPTURE) <InstallItem type="patch" secure-file="UCSInstall_CUC_12.5.1.15900-38.sgn.iso" version="12.5.1.15900-38" file="UCSInstall_CUC_12.5.1.15900-38.sgn.iso" reboot="no" signed="yes" unrestricted="no"/>|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|(CAPTURE) </InstallList>|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|success|<LVL::Info>
12/23/2021 11:19:23 file_list.sh|file_list.sh complete (rc=0)|<LVL::Info>
12/23/2021 11:19:23 file_list.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|is_upgrade_in_progress: Already locked by this process (pid: 10786).|<LVL::Debug>
12/23/2021 11:19:23 file_list.sh|release_upgrade_lock: Releasing lock (pid: 10786)|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Starting upgrade_validate_file.sh|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument method=local_dvd|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument source_dir=|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument file_name=UCSInstall_CUC_12.5.1.15900-38.sgn.iso|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument file_type=patch|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument file_signed=yes|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|is_upgrade_lock_available: Upgrade lock is available.|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|status in upgrade status.xml upgrade.stage.determining.files|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 17802)|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|clear_upgrade_status: Status file removed|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument status=upgrade.stage.validating|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|_set_upgrade_status_attribute: status set to upgrade.stage.validating|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Process local CD/DVD request|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|Unmount DVD|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|Mount /dev/cdrom on /mnt/source|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Get patch size from /mnt/source|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|patch size is 4379035648|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Check free space|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|(CAPTURE) Free space: 69835415552, Needed space: 4379035648|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|There is enough space on device to proceed.|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|Validate isofilename exists on /mnt/source|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Validate checksum_file exists on /mnt/source|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|Local CD/DVD request complete|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|success|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|upgrade_validate_file.sh complete (rc=0)|<LVL::Info>
12/23/2021 11:19:30 upgrade_validate_file.sh|Parse argument status=upgrade.stage.validated|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|_set_upgrade_status_attribute: status set to upgrade.stage.validated|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|is_upgrade_in_progress: Already locked by this process (pid: 17802).|<LVL::Debug>
12/23/2021 11:19:30 upgrade_validate_file.sh|release_upgrade_lock: Releasing lock (pid: 17802)|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Starting upgrade_get_file.sh|<LVL::Info>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument method=local_dvd|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument source_dir=|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument file_name=UCSInstall_CUC_12.5.1.15900-38.sgn.iso|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument dest_dir=/common/download/|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument version=12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument file_type=patch|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument file_signed=yes|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|is_upgrade_lock_available: Upgrade lock is available.|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|status in upgrade status.xml upgrade.stage.validated|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 19258)|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument toVersion=12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|_set_upgrade_status_attribute: toVersion set to 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|Parse argument status=upgrade.stage.downloading|<LVL::Debug>
12/23/2021 11:19:31 upgrade_get_file.sh|_set_upgrade_status_attribute: status set to upgrade.stage.downloading|<LVL::Debug>
12/23/2021 11:19:32 upgrade_get_file.sh|Process local CD/DVD request|<LVL::Info>
12/23/2021 11:19:32 upgrade_get_file.sh|src_file=/mnt/source//UCSInstall_CUC_12.5.1.15900-38.sgn.iso, dest_file=/common/download/UCSInstall_CUC_12.5.1.15900-38.sgn.iso, file_type=patch|<LVL::Debug>
12/23/2021 11:19:32 upgrade_get_file.sh|Unmounting /mnt/source incase it is mounted|<LVL::Debug>
12/23/2021 11:19:32 upgrade_get_file.sh|Mount /dev/cdrom on /mnt/source|<LVL::Debug>
12/23/2021 11:19:33 upgrade_get_file.sh|Local CD/DVD request complete|<LVL::Info>
12/23/2021 11:19:33 upgrade_get_file.sh|Download of iso file RTMTStart|<LVL::Notice>
12/23/2021 11:19:33 upgrade_get_file.sh|Parse argument status=upgrade.stage.checksumming|<LVL::Debug>
12/23/2021 11:19:33 upgrade_get_file.sh|_set_upgrade_status_attribute: status set to upgrade.stage.checksumming|<LVL::Debug>
12/23/2021 11:19:33 upgrade_get_file.sh|Create md5 "/common/download/UCSInstall_CUC_12.5.1.15900-38.sgn.iso.md5"|<LVL::Info>
12/23/2021 11:19:33 upgrade_get_file.sh|Create md5 complete|<LVL::Info>
12/23/2021 11:19:33 upgrade_get_file.sh|Authenticate file "/common/download/12.5.1.15900-38/checksum_file.sgn"|<LVL::Info>
12/23/2021 11:19:33 upgrade_get_file.sh|File authentication complete|<LVL::Debug>
12/23/2021 11:19:33 upgrade_get_file.sh|New Upgrade Software; returning|<LVL::Info>
12/23/2021 11:19:33 upgrade_get_file.sh|Download of iso file RTMTFinish|<LVL::Notice>
12/23/2021 11:19:33 upgrade_get_file.sh|Process preflight|<LVL::Info>
12/23/2021 11:19:33 upgrade_get_file.sh|Checking for preflight script|<LVL::Debug>
12/23/2021 11:19:33 upgrade_get_file.sh|Executing preflight /mnt/source/Cisco/install/bin/preflight isolocation=/mnt/source|<LVL::Info>
12/23/2021 11:19:33 preflight|Starting preflight|<LVL::Info>
12/23/2021 11:19:33 preflight|Validate preflight data|<LVL::Info>
12/23/2021 11:19:33 preflight|Preflight data validation complete|<LVL::Info>
12/23/2021 11:19:33 preflight|Determine upgrade type|<LVL::Info>
12/23/2021 11:19:33 preflight|Active Base OS version = package centos-release-server is not installed|<LVL::Debug>
12/23/2021 11:19:33 preflight|New os version(xml) = 7Server|<LVL::Debug>
12/23/2021 11:19:33 preflight|HW model = VMware|<LVL::Debug>
12/23/2021 11:19:33 preflight|Upgrade type = RU|<LVL::Debug>
12/23/2021 11:19:33 preflight|Obtain product type|<LVL::Info>
12/23/2021 11:19:34 preflight|Obtained product type UnityConnection|<LVL::Info>
12/23/2021 11:19:34 preflight|Processing preflight install mode|<LVL::Info>
12/23/2021 11:19:34 preflight|Set preflight cancel utility|<LVL::Info>
12/23/2021 11:19:34 preflight|active version 11.5.1.12900-21|<LVL::Info>
12/23/2021 11:19:34 preflight|active major 11|<LVL::Info>
12/23/2021 11:19:34 preflight|majorstring is 5.1.12900-21|<LVL::Info>
12/23/2021 11:19:34 preflight|active minor is 5|<LVL::Info>
12/23/2021 11:19:34 preflight|diffie-hellman-group14-sha1 is present in ssh_config|<LVL::Info>
12/23/2021 11:19:34 preflight|diffie-hellman-group14-sha1 is present in sshd_config|<LVL::Info>
12/23/2021 11:19:34 preflight|Checking versions to see if FIPS check is needed|<LVL::Info>
12/23/2021 11:19:34 preflight|Fips check not needed in the active version|<LVL::Info>
12/23/2021 11:19:34 preflight|Executing default process_xml_commands|<LVL::Info>
12/23/2021 11:19:34 preflight|Execute install preflight commands for UnityConnection:RU from /mnt/source/Cisco/install/preflight.xml|<LVL::Info>
12/23/2021 11:19:34 preflight|Found 10 preflight commands to execute|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (1/10): mkdir -p /common/preflight/UC/RU|<LVL::Debug>
12/23/2021 11:19:34 preflight|Preflight command returns 0|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (2/10): cp -f /usr/local/platform/conf/dynamicConfig.xml /common/preflight/UC/RU/dynamicConfig.xml|<LVL::Debug>
12/23/2021 11:19:34 preflight|Preflight command returns 1|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) cp: cannot stat `/usr/local/platform/conf/dynamicConfig.xml': No such file or directory|<LVL::Debug>
12/23/2021 11:19:34 preflight|Preflight command did not complete (1). Continuing command processing...|<LVL::Warn>
12/23/2021 11:19:34 preflight|Execute preflight command (3/10): cp -f /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp /common/preflight/UC/RU/dynamic.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) cp: cannot stat `/usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp': No such file or directory|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (4/10): cp -f /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp /common/preflight/UC/RU/install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) cp: cannot stat `/usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp': No such file or directory|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (5/10): cp -f /mnt/source/Cisco/install/dynamicConfig_RU_UC.xml /usr/local/platform/conf/dynamicConfig.xml|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (6/10): mkdir -p /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (7/10): cp -f /mnt/source/Cisco/install/dynamic_RU_UC.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (8/10): cp -f /mnt/source/Cisco/install/install-confirm-content_RU.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (9/10): /mnt/source/Cisco/install/bin/tempDynamic.preflight /mnt/source/Cisco/install/dynamic_RU_UC.jsp dynamic.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 starting tempDynamic.preflight...|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Source dir/file = /mnt/source/Cisco/install/dynamic_RU_UC.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Destination file name = dynamic.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Copying /mnt/source/Cisco/install/dynamic_RU_UC.jsp to /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 added/replaced /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/dynamic.jsp successfully|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Copying /mnt/source/Cisco/install/dynamic_RU_UC.jsp to /usr/local/thirdparty/jakarta-tomcat/temp/3-cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 added/replaced /usr/local/thirdparty/jakarta-tomcat/temp/3-cmplatform/WEB-INF/pages/install/dynamic.jsp successfully|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 ... tempDynamic.preflight completed|<LVL::Debug>
12/23/2021 11:19:34 preflight|Execute preflight command (10/10): /mnt/source/Cisco/install/bin/tempDynamic.preflight /mnt/source/Cisco/install/install-confirm-content_RU.jsp install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Source dir/file = /mnt/source/Cisco/install/install-confirm-content_RU.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Destination file name = install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Copying /mnt/source/Cisco/install/install-confirm-content_RU.jsp to /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 added/replaced /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/install-confirm-content.jsp successfully|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 Copying /mnt/source/Cisco/install/install-confirm-content_RU.jsp to /usr/local/thirdparty/jakarta-tomcat/temp/3-cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:19:34 preflight|(CAPTURE) 12/23/2021 11:19:34 added/replaced /usr/local/thirdparty/jakarta-tomcat/temp/3-cmplatform/WEB-INF/pages/install/install-confirm-content.jsp successfully|<LVL::Debug>
12/23/2021 11:19:34 preflight|Exiting with result 0|<LVL::Info>
12/23/2021 11:19:34 upgrade_get_file.sh|preflight returns 0|<LVL::Debug>
12/23/2021 11:19:34 upgrade_get_file.sh|Preflight completed successfully|<LVL::Info>
12/23/2021 11:19:36 upgrade_get_file.sh|success|<LVL::Info>
12/23/2021 11:19:36 upgrade_get_file.sh|upgrade_get_file.sh complete (rc=0)|<LVL::Info>
12/23/2021 11:19:36 upgrade_get_file.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
12/23/2021 11:19:36 upgrade_get_file.sh|is_upgrade_in_progress: Already locked by this process (pid: 19258).|<LVL::Debug>
12/23/2021 11:19:36 upgrade_get_file.sh|release_upgrade_lock: Releasing lock (pid: 19258)|<LVL::Debug>
12/23/2021 11:19:52 sd_cancelInstall.sh|Pre-upgrade cancel/clean-up initiated
12/23/2021 11:19:53 sd_cancelInstall.sh|Canceling active side processes
12/23/2021 11:19:53 sd_cancelInstall.sh|Canceling active side processes done
12/23/2021 11:19:53 sd_cancelInstall.sh|Canceling inactive side processes
12/23/2021 11:19:53 sd_cancelInstall.sh|This is not a COP, so will do IDS shared memory clean up if needed on inactive partition
12/23/2021 11:19:53 sd_cancelInstall.sh|Canceling inactive side processes done
12/23/2021 11:19:58 upgrade_install.sh|Starting Upgrade -- upgrade_install.sh|<LVL::Info>
12/23/2021 11:19:58 upgrade_install.sh|Parse argument version=12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|Parse argument dest_dir=/common/download/|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|Parse argument work_dir=/var/log/install|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|Parse argument boot|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is available.|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|status in upgrade status.xml upgrade.stage.checksumming|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 25478)|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|Parse argument status=upgrade.stage.installing|<LVL::Debug>
12/23/2021 11:19:58 upgrade_install.sh|_set_upgrade_status_attribute: status set to upgrade.stage.installing|<LVL::Debug>
12/23/2021 11:19:59 upgrade_install.sh|IOWAIT monitor disabled|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Selinux mode prior to upgrade is enforcing|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Stopped auditd...|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Changed selinux mode to permissive|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Upgrade the system|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Copy /mnt/source/Cisco/base_scripts/upgrade_manager.sh to /common/download/12.5.1.15900-38/upgrade_manager.sh|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Copy /mnt/source/Cisco/base_scripts/upgrade_manager.sh to /common/download/12.5.1.15900-38/upgrade_manager.sh complete|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|Start upgrade manager|<LVL::Info>
12/23/2021 11:20:01 upgrade_install.sh|/common/download/12.5.1.15900-38/upgrade_manager.sh type=upgrade basepath=/common/download/12.5.1.15900-38 file_name= logfile=/var/log/install/install_log_2021-12-23.11.19.16.log resultfile=/var/log/install/upgrade-results.xml work_dir=/var/log/install intf_file=/common/download/12.5.1.15900-38/upgrade_manager.xml to_version=12.5.1.15900-38 switch|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument type=upgrade|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument basepath=/common/download/12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument file_name=|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument logfile=/var/log/install/install_log_2021-12-23.11.19.16.log|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument resultfile=/var/log/install/upgrade-results.xml|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument work_dir=/var/log/install|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument intf_file=/common/download/12.5.1.15900-38/upgrade_manager.xml|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument to_version=12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Parse argument switch|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|upgrade_type="upgrade"|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|L2 upgrade|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|new upgrade version=12.5.1.15900-38|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Cleanup data from a prior upgrade attempt|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Removing any /grub/boot/grub2/grub.cfg.recovery|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Removing previous rpm_archive /common/rpm-archive/12.5.1.15900-38|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|/var/log/active/installed_options exists|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|removing the data in ciscocm.cuc_preUpgradeCheck-004.cop file|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|removing the data in ciscocm.cuc_upgrade_12_0_v1.2.k3.cop file|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|removing the data in ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop file|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Initialize install support functions|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Calling "source /mnt/source/Cisco/install/bin/install_func"|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Initialize install support functions complete|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Check for Refresh Upgrade|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Check if /mnt/source/upgradeConfig.xml exists|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Checking Base OS release version (6Server, 7Server)|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Initiate Refresh Upgrade|<LVL::Info>
12/23/2021 11:20:02 upgrade_manager.sh|Copy /mnt/source/Cisco/install/bin/refresh_upgrade to /common/download/12.5.1.15900-38/refresh_upgrade|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Check that /common/download/12.5.1.15900-38/refresh_upgrade exists and is executable|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Creating SELINUX_RU_RELABEL_PARTB crumb file|<LVL::Debug>
12/23/2021 11:20:02 upgrade_manager.sh|Calling exec /common/download/12.5.1.15900-38/refresh_upgrade type=upgrade basepath=/common/download/12.5.1.15900-38 file_name= logfile=/var/log/install/install_log_2021-12-23.11.19.16.log resultfile=/var/log/install/upgrade-results.xml work_dir=/var/log/install intf_file=/common/download/12.5.1.15900-38/upgrade_manager.xml to_version=12.5.1.15900-38 switch|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument type=upgrade|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument basepath=/common/download/12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument file_name=|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument logfile=/var/log/install/install_log_2021-12-23.11.19.16.log|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument resultfile=/var/log/install/upgrade-results.xml|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument work_dir=/var/log/install|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument intf_file=/common/download/12.5.1.15900-38/upgrade_manager.xml|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument to_version=12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Parse argument switch|<LVL::Debug>
12/23/2021 11:20:02 refresh_upgrade|Refresh Upgrade Starting|<LVL::Info>
12/23/2021 11:20:02 refresh_upgrade|IOWAIT monitor starting|<LVL::Info>
12/23/2021 11:20:02 refresh_upgrade|Checksum the upgrade source on /mnt/source|<LVL::Info>
12/23/2021 11:20:02 refresh_upgrade|Calling sha1sum -c /common/download/12.5.1.15900-38/checksum_file|<LVL::Debug>
12/23/2021 11:21:01 refresh_upgrade|Checksum complete|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|Prepare Refresh Upgrade support directory|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|Make /common/mnt/product_img directory|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|Calling mkdir -p /common/mnt/product_img|<LVL::Debug>
12/23/2021 11:21:01 refresh_upgrade|Setup support directories|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|Calling rm -rf /common/download/12.5.1.15900-38/Cisco|<LVL::Debug>
12/23/2021 11:21:01 refresh_upgrade|Calling mkdir -p /common/download/12.5.1.15900-38/Cisco|<LVL::Debug>
12/23/2021 11:21:01 refresh_upgrade|Create /common/cisco link to /common/download/12.5.1.15900-38/Cisco|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|Calling rm -rf /common/cisco|<LVL::Debug>
12/23/2021 11:21:01 refresh_upgrade|Calling ln -s /common/download/12.5.1.15900-38/Cisco /common/cisco|<LVL::Debug>
12/23/2021 11:21:01 refresh_upgrade|Copy /mnt/source/images/product.img to /common/download/12.5.1.15900-38/product.img|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|Copy files from /common/download/12.5.1.15900-38/product.img to /common/download/12.5.1.15900-38/Cisco|<LVL::Info>
12/23/2021 11:21:01 refresh_upgrade|unarchiving /common/download/12.5.1.15900-38/product.img to /common/mnt/product_img|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/iproduct.sh /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/iproduct.sh|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/ihardware.sh /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/ihardware.sh|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/ihistory.sh /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/ihistory.sh|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/xproduct.sh /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/xproduct.sh|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/xcomponent.sh /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/xcomponent.sh|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/xplatformconfig.sh /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/xplatformconfig.sh|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/install_emailer /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/install_emailer|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Calling cp -rf /common/mnt/product_img/usr/cisco/bin/component_install /common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/component_install|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|removing /common/mnt/product_img|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Delete /common/download/12.5.1.15900-38/product.img|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Copying /mnt/source/Cisco/install to /common/download/12.5.1.15900-38/Cisco|<LVL::Debug>
12/23/2021 11:21:02 refresh_upgrade|Setup install information in /common/download/12.5.1.15900-38/Cisco|<LVL::Info>
12/23/2021 11:21:03 refresh_upgrade|Setting up cisco specific enviroment|<LVL::Info>
12/23/2021 11:21:03 refresh_upgrade|PATH=/common/download/12.5.1.15900-38/Cisco/usr/cisco/bin:/usr/local/bin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/X11R6/bin:/usr/local/thirdparty/java/j2sdk/bin|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|LD_LIBRARY_PATH=/common/download/12.5.1.15900-38/Cisco/lib:/opt/cisco/install/lib:|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|PYTHONPATH=/common/download/12.5.1.15900-38/Cisco/python:/usr/local/cm/lib:/usr/local/cm/lib:/usr/local/cm/lib:/usr/local/cm/lib:|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|CISCO_INSTALL_CONF_PATH=/common/download/12.5.1.15900-38/Cisco/install/conf|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|CISCO_INSTALL_BIN_PATH=/common/download/12.5.1.15900-38/Cisco/usr/cisco/bin /opt/cisco/install/bin /usr/local/bin/base_scripts|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|CISCO_PLATFORMCONF_PATH=/common/cisco /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|CISCO_INSTALL_LIB_PATH=/usr/local/bin/base_scripts|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|Set logging globals for upgrade|<LVL::Info>
12/23/2021 11:21:03 refresh_upgrade|Before: ILOG_CONTEXT="Upgrade", ILOG_FILE="/var/log/install/install_log_2021-12-23.11.19.16.log", ILOG_RESULTS_FILE="/var/log/install/upgrade-results.xml"|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|After: ILOG_CONTEXT="Upgrade", ILOG_FILE="/common/log/install/install_log_2021-12-23.11.19.16.log", ILOG_RESULTS_FILE="/common/log/install/upgrade-results.xml"|<LVL::Debug>
12/23/2021 11:21:03 refresh_upgrade|Initialize APIs|<LVL::Info>
12/23/2021 11:21:03 refresh_upgrade|Initializing the product API|<LVL::Info>
12/23/2021 11:21:03 refresh_upgrade|Initializing the hardware API|<LVL::Info>
12/23/2021 11:21:04 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<LVL::Debug>
12/23/2021 11:21:08 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|Initializing the history log API|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Initializing the xplatformconfig API|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Initializing the xproduct API|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Initializing the upgrade lib API|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Initialize setup functions|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Copying /mnt/source/Cisco/install/setup/utils.sh to /common/download/12.5.1.15900-38/Cisco|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|Calling "source /common/download/12.5.1.15900-38/Cisco/utils.sh"|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|Copying /mnt/source/Cisco/install/lib/check_upgrade_space.sh to /common/download/12.5.1.15900-38/Cisco|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|Calling "source /common/download/12.5.1.15900-38/Cisco/check_upgrade_space.sh"|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|Initialize setup functions complete|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Parse argument upgradeType=RU|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|_set_upgrade_status_attribute: upgradeType set to RU|<LVL::Debug>
12/23/2021 11:21:08 refresh_upgrade|Getting deployment ID from active side|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Copy /usr/local/platform/conf/platformConfig.xml to /common/cisco/platformConfig.xml|<LVL::Info>
12/23/2021 11:21:08 refresh_upgrade|Calling "cp /usr/local/platform/conf/platformConfig.xml /common/cisco/platformConfig.xml"|<LVL::Debug>
12/23/2021 11:21:09 refresh_upgrade|Initialize staging area|<LVL::Info>
12/23/2021 11:21:09 refresh_upgrade|Initialize globals for hard drive|<LVL::Debug>
12/23/2021 11:21:09 refresh_upgrade|Calling rm -rf /common/refresh_upgrade /common/component|<LVL::Debug>
12/23/2021 11:21:09 refresh_upgrade|/common/download/12.5.1.15900-38/Cisco/bin/install_emailer not found!|<LVL::Info>
12/23/2021 11:21:09 refresh_upgrade|Copy /mnt/source to /common/refresh_upgrade|<LVL::Info>
12/23/2021 11:21:09 refresh_upgrade|Execute find /mnt/source and cpio to /common/refresh_upgrade. This may take several minutes.|<LVL::Debug>
12/23/2021 11:21:57 refresh_upgrade|Copy source files to staging area complete|<LVL::Info>
12/23/2021 11:21:57 refresh_upgrade|Initialize staging area complete|<LVL::Info>
12/23/2021 11:21:57 refresh_upgrade|Check if the upgrade is allowed|<LVL::Info>
12/23/2021 11:21:57 refresh_upgrade|Components found for connection deployment - upgradeable|<LVL::Info>
12/23/2021 11:21:57 refresh_upgrade|connection deployment upgradable |<LVL::Debug>
12/23/2021 11:21:57 refresh_upgrade|Validate hardware for the upgrade|<LVL::Info>
12/23/2021 11:21:57 refresh_upgrade|Hardware is supported for the upgrade|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Validate hardware for "connection" deployment|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Hardware is supported for "connection" deployment|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Validate from version 11.5.1.12900-21|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Upgrade from 11.5.1.12900-21 allowed|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Validate free space for the upgrade|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Calculating Free Space|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Location: /common|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Type: free_partition_space|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Size: 69757120512|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Location: /var/log/inactive/|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Type: used_directory_space|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Size: 4096|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Calculating Needed Space|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Location: /mnt/source/|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Size: 4376320569|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Location: DB|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Type: bytes|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Size: 9663676416|<LVL::Info>
12/23/2021 11:22:03 refresh_upgrade|Size: 576716800|<LVL::Info>
12/23/2021 11:22:04 refresh_upgrade|Location: check_swap_space.sh|<LVL::Info>
12/23/2021 11:22:04 refresh_upgrade|Type: script|<LVL::Info>
12/23/2021 11:22:04 refresh_upgrade|Size: 0|<LVL::Info>
12/23/2021 11:22:04 refresh_upgrade|(CAPTURE) Free space: 69757124608, Needed space: 14616713785|<LVL::Debug>
12/23/2021 11:22:04 refresh_upgrade|Free space validation complete|<LVL::Info>
12/23/2021 11:22:39 refresh_upgrade|Run component export scripts|<LVL::Debug>
12/23/2021 11:22:39 component_install|Initializing xproduct.sh API|<LVL::Debug>
12/23/2021 11:22:39 component_install|Initializing xcomponent.sh API|<LVL::Debug>
12/23/2021 11:22:39 component_install|Initializing xplatformconfig.sh API|<LVL::Debug>
12/23/2021 11:22:39 component_install|PATH=/usr/local/cm/db/informix:/usr/local/cm/db/informix/bin:/usr/local/cm/bin:/usr/local//thirdparty/java/j2sdk/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/sbin:/home/sftpuser:/root/.security:/root/bin:/common/download/12.5.1.15900-38/Cisco/usr/cisco/bin:/usr/local/bin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/X11R6/bin:/usr/local/thirdparty/java/j2sdk/bin|<LVL::Info>
12/23/2021 11:22:39 component_install|LD_LIBRARY_PATH=/usr/local/lib:/usr/local/thirdparty/java/j2sdk/jre/lib/i386:/usr/local/thirdparty/java/j2sdk/jre/lib/i386/server:/usr/lib/pgsql:/usr/lib:/usr/local/cm/lib:/usr/local/platform/lib:/common/download/12.5.1.15900-38/Cisco/lib:/opt/cisco/install/lib:|<LVL::Info>
12/23/2021 11:22:39 component_install|Parse argument export|<LVL::Debug>
12/23/2021 11:22:39 component_install|Parse argument mode=refresh-upgrade|<LVL::Debug>
12/23/2021 11:22:39 component_install|Parse argument install_root=/common/refresh_upgrade/Cisco|<LVL::Debug>
12/23/2021 11:22:39 component_install|Parse argument data_root=/common|<LVL::Debug>
12/23/2021 11:22:39 component_install|Run component export scripts, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:22:39 component_install|Initialize product data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:22:39 component_install|Initialize "to" side product version|<LVL::Info>
12/23/2021 11:22:39 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:22:39 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:22:39 component_install|Initialize "to" side product version complete|<LVL::Info>
12/23/2021 11:22:39 component_install|Initialize "from" side product version|<LVL::Info>
12/23/2021 11:22:39 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:22:40 component_install|Got version 11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:22:40 component_install|Initialize "from" side product version complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize product data complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize ucos "to" side version|<LVL::Info>
12/23/2021 11:22:40 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:22:40 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:22:40 component_install|Initialize ucos "to" side version complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize ucos "from" side version|<LVL::Info>
12/23/2021 11:22:40 component_install|Component ucos available on active side|<LVL::Debug>
12/23/2021 11:22:40 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:22:40 component_install|Initialize ucos "from" side version complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize global data complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Build the command list for ucos|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize command list|<LVL::Debug>
12/23/2021 11:22:40 component_install|Build ucos export phase commands|<LVL::Debug>
12/23/2021 11:22:40 component_install|Processing ucos export element|<LVL::Debug>
12/23/2021 11:22:40 component_install|Building the command list for ucos is complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Command execution for ucos component RTMTStart|<LVL::Notice>
12/23/2021 11:22:40 component_install|Execute commands in the command list for ucos component|<LVL::Info>
12/23/2021 11:22:40 component_install|No commands to execute for ucos component|<LVL::Info>
12/23/2021 11:22:40 component_install|Command execution for ucos component is complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Command execution for ucos component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:40 component_install|Initialize ucplatform "to" side version|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize ucplatform "to" side version complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Initialize ucplatform "from" side version|<LVL::Info>
12/23/2021 11:22:40 component_install|Component ucplatform available on active side|<LVL::Debug>
12/23/2021 11:22:40 component_install|Initialize ucplatform "from" side version complete|<LVL::Info>
12/23/2021 11:22:40 component_install|Build the command list for ucplatform|<LVL::Info>
12/23/2021 11:22:40 component_install|Build ucplatform export phase commands|<LVL::Debug>
12/23/2021 11:22:40 component_install|Processing ucplatform export element|<LVL::Debug>
12/23/2021 11:22:40 component_install|Processing ucplatform script element|<LVL::Debug>
12/23/2021 11:22:40 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:22:40 component_install|Add "security_prepare RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:40 component_install|Add "password_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:40 component_install|Add "ssh_keys_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:40 component_install|Add "platform_certs_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Processing ucplatform script element|<LVL::Debug>
12/23/2021 11:22:41 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "is_ils_active RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "servm_export RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "network_files_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "drf_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "cup_platformConfig_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "ccm_platformConfig_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "ccm_encrypt_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Add "setup_fior RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:41 component_install|Building the command list for ucplatform is complete|<LVL::Info>
12/23/2021 11:22:41 component_install|Command execution for ucplatform component RTMTStart|<LVL::Notice>
12/23/2021 11:22:41 component_install|Execute commands in the command list for ucplatform component|<LVL::Info>
12/23/2021 11:22:41 component_install|Search path is /common/refresh_upgrade/Cisco/ucplatform/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:41 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/security_prepare|<LVL::Debug>
12/23/2021 11:22:41 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/security_prepare RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Parse arguments|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Validate arguments|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Initialize global variables|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Handle Security Information|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export security information|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export /etc/shadow file|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export login warning message|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Exporing branding and skin data|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export SFTP data|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export DRF data|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export CCM Service Data|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|Export IPSec Data to /common/component/ucplatform|<LVL::Debug>
12/23/2021 11:22:41 security_prepare|exporting certificates for non-fips mode|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export Tomcat Data|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export FIPS settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|fips.cnf found copying fips.cnf|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export Enhanced Security Mode settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export System-auth settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|system-auth found, copying it|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export commonCriteria settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Exporting Minimum TLS Version Information|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|MinimumTLSVersion information does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Exporting Common Conf File|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Common Conf File does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Exporting CipherInterfaceAssociation XML|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|CipherInterfaceAssociation XML does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Exporting haproxy_cli_config XML|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|haproxy_cli_config XML does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export igmpVersion settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|sysctl.conf found, copying igmpVersion Settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|Export Filebeat settings|<LVL::Debug>
12/23/2021 11:22:42 security_prepare|filebeat.yml found, copying it|<LVL::Debug>
12/23/2021 11:22:43 security_prepare|existing version is 1.1.2|<LVL::Debug>
12/23/2021 11:22:43 security_prepare|Filebeat backup file is not present|<LVL::Debug>
12/23/2021 11:22:43 security_prepare|filebeat_status.txt found, copying it|<LVL::Debug>
12/23/2021 11:22:43 security_prepare|Export contactSearch settings|<LVL::Debug>
12/23/2021 11:22:43 security_prepare|contactSearchAuth.cnf found, copying it|<LVL::Debug>
12/23/2021 11:22:44 security_prepare|Export webappSessionLimit settings|<LVL::Debug>
12/23/2021 11:22:44 security_prepare|Export Headset Config Data|<LVL::Info>
12/23/2021 11:22:44 security_prepare|headsetConfig.json does not exist to export under location /usr/local/cm/db/json|<LVL::Info>
12/23/2021 11:22:44 security_prepare|Export of sysconfig language(i18n) file complete.|<LVL::Info>
12/23/2021 11:22:44 security_prepare|Export of sysconfig keyboard file complete.|<LVL::Info>
12/23/2021 11:22:44 security_prepare|security information prepare successful|<LVL::Info>
12/23/2021 11:22:44 component_install|Search path is /common/refresh_upgrade/Cisco/ucplatform/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:44 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/password_migrate|<LVL::Debug>
12/23/2021 11:22:44 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/password_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:44 password_migrate|Handle password information|<LVL::Debug>
12/23/2021 11:22:44 password_migrate|Export password information|<LVL::Info>
12/23/2021 11:22:44 password_migrate|Calling mkdir -p /common/component/ucplatform/etc/pam.d|<LVL::Info>
12/23/2021 11:22:44 password_migrate|Export useradd file|<LVL::Debug>
12/23/2021 11:22:44 password_migrate|useradd Copied Successfully|<LVL::Info>
12/23/2021 11:22:44 password_migrate|password information migrate successful|<LVL::Info>
12/23/2021 11:22:44 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/ssh_keys_migrate|<LVL::Debug>
12/23/2021 11:22:44 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/ssh_keys_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:44 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/platform_certs_migrate|<LVL::Debug>
12/23/2021 11:22:44 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/platform_certs_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:44 platform_certs_migrate|Source major version: 11|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|Export platform certificates|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|starting refresh upgrade export certs copy|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|creating /common/component/ucplatform|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|Set 755 permissions for files under /usr/local/platform/.security/tomcat/certs|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|Set 755 permissions for files under /usr/local/platform/.security/ipsec/certs|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|ITLRECOVERY_OLD_PATH = /usr/local/cm/|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|Set 755 permissions for files under /usr/local/platform/.security/tomcat-ECDSA/certs|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|exporting certmon config|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|creating /common/component/ucplatform/config|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|copy /usr/local/platform/conf/certMonitorConfig.xml /common/component/ucplatform/conf/|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|Export bulk sftp config|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|sftp config not available|<LVL::Info>
12/23/2021 11:22:44 platform_certs_migrate|platform certificates migrate successful|<LVL::Info>
12/23/2021 11:22:44 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/is_ils_active|<LVL::Debug>
12/23/2021 11:22:44 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/is_ils_active RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 component_install|Search path is /common/refresh_upgrade/Cisco/ucplatform/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/servm_export|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/servm_export RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 servm_export|Start servm Export processing|<LVL::Info>
12/23/2021 11:22:45 servm_export|Copying /usr/local/cm//../platform/conf/activate.conf to /common/component/ucplatform|<LVL::Info>
12/23/2021 11:22:45 servm_export|Copying /usr/local/cm//../platform/conf/services.conf to /common/component/ucplatform|<LVL::Info>
12/23/2021 11:22:45 servm_export|SUCCESS: servm Export processing completed|<LVL::Info>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/network_files_migrate|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/network_files_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Export network configuration files to /common/component/ucplatform/etc/sysconfig/network-scripts|<LVL::Info>
12/23/2021 11:22:45 network_files_migrate|Calling mkdir -p /common/component/ucplatform/etc/sysconfig/network-scripts|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Calling mkdir -p /common/component/ucplatform/common|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copy network configuration files|<LVL::Info>
12/23/2021 11:22:45 network_files_migrate|Copying /etc/sysconfig/network-scripts/ifcfg-eth0 to /common/component/ucplatform/etc/sysconfig/network-scripts/ifcfg-eth0|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying /etc/sysconfig/network to /common/component/ucplatform/etc/sysconfig/network|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying /etc/hosts to /common/component/ucplatform/etc/hosts|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying /etc/resolv.conf to /common/component/ucplatform/etc/resolv.conf|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying //etc/nsswitch.conf to /common/component/ucplatform/etc/nsswitch.conf|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying /etc/ntp.conf to /common/component/ucplatform/etc/ntp.conf|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying /etc/ntp/keys to /common/component/ucplatform/etc/ntp|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copying /common/sysctl.conf.append to /common/component/ucplatform/common/sysctl.conf.append|<LVL::Debug>
12/23/2021 11:22:45 network_files_migrate|Copy network configuration files complete|<LVL::Info>
12/23/2021 11:22:45 network_files_migrate|Export network configuration files complete|<LVL::Info>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/drf_migrate|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/drf_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/cup_platformConfig_migrate|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/cup_platformConfig_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/ccm_platformConfig_migrate|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/ccm_platformConfig_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/ccm_encrypt_migrate|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/ccm_encrypt_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 ccm_encrypt_migrate|Export ccm encryption data.|<LVL::Debug>
12/23/2021 11:22:45 ccm_encrypt_migrate|Calling mkdir -p /common/component/ucplatform/ccmencrypt|<LVL::Debug>
12/23/2021 11:22:45 ccm_encrypt_migrate|Export ccm encrypt data complete.|<LVL::Debug>
12/23/2021 11:22:45 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform/scripts/setup_fior|<LVL::Debug>
12/23/2021 11:22:45 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform/scripts/setup_fior RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|Parse arguments|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|Validate arguments|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|Initialize global variables|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|Handle Fior Information|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|prod value is Basic Install|<LVL::Info>
12/23/2021 11:22:45 setup_fior|Export fior information|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|Export FIOR data to /common/component/ucplatform|<LVL::Debug>
12/23/2021 11:22:45 setup_fior|Fior information setup is successful|<LVL::Info>
12/23/2021 11:22:45 component_install|Command execution for ucplatform component is complete|<LVL::Info>
12/23/2021 11:22:45 component_install|Command execution for ucplatform component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:45 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:22:45 component_install|Initialize ucplatform_cluster "to" side version|<LVL::Info>
12/23/2021 11:22:45 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:22:45 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:22:45 component_install|Initialize ucplatform_cluster "to" side version complete|<LVL::Info>
12/23/2021 11:22:45 component_install|Initialize ucplatform_cluster "from" side version|<LVL::Info>
12/23/2021 11:22:45 component_install|Component ucplatform_cluster available on active side|<LVL::Debug>
12/23/2021 11:22:45 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:22:46 component_install|Got version 11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:22:46 component_install|Initialize ucplatform_cluster "from" side version complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Initialize global data complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Build the command list for ucplatform_cluster|<LVL::Info>
12/23/2021 11:22:46 component_install|Initialize command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Build ucplatform_cluster export phase commands|<LVL::Debug>
12/23/2021 11:22:46 component_install|Processing ucplatform_cluster export element|<LVL::Debug>
12/23/2021 11:22:46 component_install|Processing ucplatform_cluster script element|<LVL::Debug>
12/23/2021 11:22:46 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "platform_sso_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_cluster /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Building the command list for ucplatform_cluster is complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Command execution for ucplatform_cluster component RTMTStart|<LVL::Notice>
12/23/2021 11:22:46 component_install|Execute commands in the command list for ucplatform_cluster component|<LVL::Info>
12/23/2021 11:22:46 component_install|Search path is /common/refresh_upgrade/Cisco/ucplatform_cluster/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:46 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_cluster/scripts/platform_sso_migrate|<LVL::Debug>
12/23/2021 11:22:46 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_cluster/scripts/platform_sso_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_cluster /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:46 component_install|Command execution for ucplatform_cluster component is complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Command execution for ucplatform_cluster component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:46 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:22:46 component_install|Initialize ucplatform_saml_sso "to" side version|<LVL::Info>
12/23/2021 11:22:46 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:22:46 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:22:46 component_install|Initialize ucplatform_saml_sso "to" side version complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Initialize ucplatform_saml_sso "from" side version|<LVL::Info>
12/23/2021 11:22:46 component_install|Component ucplatform_saml_sso available on active side|<LVL::Debug>
12/23/2021 11:22:46 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:22:46 component_install|Initialize ucplatform_saml_sso "from" side version complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Build the command list for ucplatform_saml_sso|<LVL::Info>
12/23/2021 11:22:46 component_install|Build ucplatform_saml_sso export phase commands|<LVL::Debug>
12/23/2021 11:22:46 component_install|Processing ucplatform_saml_sso export element|<LVL::Debug>
12/23/2021 11:22:46 component_install|Processing ucplatform_saml_sso script element|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "platform_samlsso_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_saml_sso /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Building the command list for ucplatform_saml_sso is complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Command execution for ucplatform_saml_sso component RTMTStart|<LVL::Notice>
12/23/2021 11:22:46 component_install|Execute commands in the command list for ucplatform_saml_sso component|<LVL::Info>
12/23/2021 11:22:46 component_install|Search path is /common/refresh_upgrade/Cisco/ucplatform_saml_sso/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:46 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_saml_sso/scripts/platform_samlsso_migrate|<LVL::Debug>
12/23/2021 11:22:46 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_saml_sso/scripts/platform_samlsso_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_saml_sso /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:46 platform_samlsso_migrate|Source major version: 11|<LVL::Info>
12/23/2021 11:22:46 component_install|Command execution for ucplatform_saml_sso component is complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Command execution for ucplatform_saml_sso component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:46 component_install|Initialize ucplatform_post "to" side version|<LVL::Info>
12/23/2021 11:22:46 component_install|Initialize ucplatform_post "to" side version complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Initialize ucplatform_post "from" side version|<LVL::Info>
12/23/2021 11:22:46 component_install|Component ucplatform_post available on active side|<LVL::Debug>
12/23/2021 11:22:46 component_install|Initialize ucplatform_post "from" side version complete|<LVL::Info>
12/23/2021 11:22:46 component_install|Build the command list for ucplatform_post|<LVL::Info>
12/23/2021 11:22:46 component_install|Build ucplatform_post export phase commands|<LVL::Debug>
12/23/2021 11:22:46 component_install|Processing ucplatform_post export element|<LVL::Debug>
12/23/2021 11:22:46 component_install|Processing ucplatform_post script element|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "security_prepare RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "password_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "ssh_keys_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "network_files_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "drf_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:46 component_install|Add "upgrade_config_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:47 component_install|Processing ucplatform_post script element|<LVL::Debug>
12/23/2021 11:22:47 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:22:47 component_install|Add "cli_configuration RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:47 component_install|Add "sshd_configuration RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:47 component_install|Building the command list for ucplatform_post is complete|<LVL::Info>
12/23/2021 11:22:47 component_install|Command execution for ucplatform_post component RTMTStart|<LVL::Notice>
12/23/2021 11:22:47 component_install|Execute commands in the command list for ucplatform_post component|<LVL::Info>
12/23/2021 11:22:47 component_install|Search path is /common/refresh_upgrade/Cisco/ucplatform_post/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/security_prepare|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/security_prepare RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Parse arguments|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Validate arguments|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Initialize global variables|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Handle Security Information|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export security information|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export /etc/shadow file|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export login warning message|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Exporing branding and skin data|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export SFTP data|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export DRF data|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export CCM Service Data|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export IPSec Data to /common/component/ucplatform_post|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|exporting certificates for non-fips mode|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export Tomcat Data|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export FIPS settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|fips.cnf found copying fips.cnf|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export Enhanced Security Mode settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export System-auth settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|system-auth found, copying it|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export commonCriteria settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Exporting Minimum TLS Version Information|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|MinimumTLSVersion information does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Exporting Common Conf File|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Common Conf File does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Exporting CipherInterfaceAssociation XML|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|CipherInterfaceAssociation XML does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Exporting haproxy_cli_config XML|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|haproxy_cli_config XML does not exist in /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export igmpVersion settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|sysctl.conf found, copying igmpVersion Settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export Filebeat settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|filebeat.yml found, copying it|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|existing version is 1.1.2|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Filebeat backup file is not present|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|filebeat_status.txt found, copying it|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export contactSearch settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|contactSearchAuth.cnf found, copying it|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export webappSessionLimit settings|<LVL::Debug>
12/23/2021 11:22:47 security_prepare|Export Headset Config Data|<LVL::Info>
12/23/2021 11:22:47 security_prepare|headsetConfig.json does not exist to export under location /usr/local/cm/db/json|<LVL::Info>
12/23/2021 11:22:47 security_prepare|Export of sysconfig language(i18n) file complete.|<LVL::Info>
12/23/2021 11:22:47 security_prepare|Export of sysconfig keyboard file complete.|<LVL::Info>
12/23/2021 11:22:47 security_prepare|security information prepare successful|<LVL::Info>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/password_migrate|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/password_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 password_migrate|Handle password information|<LVL::Debug>
12/23/2021 11:22:47 password_migrate|Export password information|<LVL::Info>
12/23/2021 11:22:47 password_migrate|Calling mkdir -p /common/component/ucplatform_post/etc/pam.d|<LVL::Info>
12/23/2021 11:22:47 password_migrate|Export useradd file|<LVL::Debug>
12/23/2021 11:22:47 password_migrate|useradd Copied Successfully|<LVL::Info>
12/23/2021 11:22:47 password_migrate|password information migrate successful|<LVL::Info>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/ssh_keys_migrate|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/ssh_keys_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/network_files_migrate|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/network_files_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Export network configuration files to /common/component/ucplatform_post/etc/sysconfig/network-scripts|<LVL::Info>
12/23/2021 11:22:47 network_files_migrate|Calling mkdir -p /common/component/ucplatform_post/etc/sysconfig/network-scripts|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Calling mkdir -p /common/component/ucplatform_post/common|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copy network configuration files|<LVL::Info>
12/23/2021 11:22:47 network_files_migrate|Copying /etc/sysconfig/network-scripts/ifcfg-eth0 to /common/component/ucplatform_post/etc/sysconfig/network-scripts/ifcfg-eth0|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying /etc/sysconfig/network to /common/component/ucplatform_post/etc/sysconfig/network|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying /etc/hosts to /common/component/ucplatform_post/etc/hosts|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying /etc/resolv.conf to /common/component/ucplatform_post/etc/resolv.conf|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying //etc/nsswitch.conf to /common/component/ucplatform_post/etc/nsswitch.conf|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying /etc/ntp.conf to /common/component/ucplatform_post/etc/ntp.conf|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying /etc/ntp/keys to /common/component/ucplatform_post/etc/ntp|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copying /common/sysctl.conf.append to /common/component/ucplatform_post/common/sysctl.conf.append|<LVL::Debug>
12/23/2021 11:22:47 network_files_migrate|Copy network configuration files complete|<LVL::Info>
12/23/2021 11:22:47 network_files_migrate|Export network configuration files complete|<LVL::Info>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/drf_migrate|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/drf_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/upgrade_config_migrate|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/upgrade_config_migrate RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 |Export upgrade config data.|<LVL::Info>
12/23/2021 11:22:47 |simpleUpgradeConfig.xml does not exist. to export under location /usr/local/platform/conf|<LVL::Debug>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/cli_configuration|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/cli_configuration RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Parse arguments|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Validate arguments|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Initialize global variables|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Handle Cli Information|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Export cli information|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Export Cli data to /common/component/ucplatform_post|<LVL::Debug>
12/23/2021 11:22:47 cli_configuration|Cli Copied Successfully|<LVL::Info>
12/23/2021 11:22:47 cli_configuration|CLI information setup is successful|<LVL::Info>
12/23/2021 11:22:47 component_install|Checking command /common/refresh_upgrade/Cisco/ucplatform_post/scripts/sshd_configuration|<LVL::Debug>
12/23/2021 11:22:47 component_install|Execute "/common/refresh_upgrade/Cisco/ucplatform_post/scripts/sshd_configuration RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucplatform_post /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|Parse arguments|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|Validate arguments|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|Initialize global variables|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|Handle sshd Information|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|Export sshd information|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|Export sshd data to /common/component/ucplatform_post|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|sshd Copied Successfully|<LVL::Info>
12/23/2021 11:22:48 sshd_configuration|Export limits conf to /common/component/ucplatform_post|<LVL::Debug>
12/23/2021 11:22:48 sshd_configuration|limit.conf Copied Successfully|<LVL::Info>
12/23/2021 11:22:48 sshd_configuration|sshd information setup is successful|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for ucplatform_post component is complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for ucplatform_post component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:48 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize thirdparty "to" side version|<LVL::Info>
12/23/2021 11:22:48 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:22:48 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:22:48 component_install|Initialize thirdparty "to" side version complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize thirdparty "from" side version|<LVL::Info>
12/23/2021 11:22:48 component_install|Component thirdparty available on active side|<LVL::Debug>
12/23/2021 11:22:48 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:22:48 component_install|Got version 11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:22:48 component_install|Initialize thirdparty "from" side version complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize global data complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Build the command list for thirdparty|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize command list|<LVL::Debug>
12/23/2021 11:22:48 component_install|Build thirdparty export phase commands|<LVL::Debug>
12/23/2021 11:22:48 component_install|Processing thirdparty export element|<LVL::Debug>
12/23/2021 11:22:48 component_install|Building the command list for thirdparty is complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for thirdparty component RTMTStart|<LVL::Notice>
12/23/2021 11:22:48 component_install|Execute commands in the command list for thirdparty component|<LVL::Info>
12/23/2021 11:22:48 component_install|No commands to execute for thirdparty component|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for thirdparty component is complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for thirdparty component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:48 component_install|Initialize serviceability_core "to" side version|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize serviceability_core "to" side version complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize serviceability_core "from" side version|<LVL::Info>
12/23/2021 11:22:48 component_install|Component serviceability_core available on active side|<LVL::Debug>
12/23/2021 11:22:48 component_install|Initialize serviceability_core "from" side version complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Build the command list for serviceability_core|<LVL::Info>
12/23/2021 11:22:48 component_install|Build serviceability_core export phase commands|<LVL::Debug>
12/23/2021 11:22:48 component_install|Processing serviceability_core export element|<LVL::Debug>
12/23/2021 11:22:48 component_install|Building the command list for serviceability_core is complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for serviceability_core component RTMTStart|<LVL::Notice>
12/23/2021 11:22:48 component_install|Execute commands in the command list for serviceability_core component|<LVL::Info>
12/23/2021 11:22:48 component_install|No commands to execute for serviceability_core component|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for serviceability_core component is complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for serviceability_core component RTMTFinish|<LVL::Notice>
12/23/2021 11:22:48 component_install|Initialize database "to" side version|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize database "to" side version complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Initialize database "from" side version|<LVL::Info>
12/23/2021 11:22:48 component_install|Component database available on active side|<LVL::Debug>
12/23/2021 11:22:48 component_install|Initialize database "from" side version complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Build the command list for database|<LVL::Info>
12/23/2021 11:22:48 component_install|Build database export phase commands|<LVL::Debug>
12/23/2021 11:22:48 component_install|Processing database export element|<LVL::Debug>
12/23/2021 11:22:48 component_install|Processing database script element|<LVL::Debug>
12/23/2021 11:22:48 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:22:48 component_install|Add "exportcucm.py RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/database /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:22:48 component_install|Building the command list for database is complete|<LVL::Info>
12/23/2021 11:22:48 component_install|Command execution for database component RTMTStart|<LVL::Notice>
12/23/2021 11:22:48 component_install|Execute commands in the command list for database component|<LVL::Info>
12/23/2021 11:22:48 component_install|Search path is /common/refresh_upgrade/Cisco/database/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:22:48 component_install|Checking command /common/refresh_upgrade/Cisco/database/scripts/exportcucm.py|<LVL::Debug>
12/23/2021 11:22:48 component_install|Execute "/common/refresh_upgrade/Cisco/database/scripts/exportcucm.py RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/database /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:25 component_install|Command execution for database component is complete|<LVL::Info>
12/23/2021 11:23:25 component_install|Command execution for database component RTMTFinish|<LVL::Notice>
12/23/2021 11:23:25 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:23:25 component_install|Initialize serviceability_common "to" side version|<LVL::Info>
12/23/2021 11:23:25 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:23:25 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:23:25 component_install|Initialize serviceability_common "to" side version complete|<LVL::Info>
12/23/2021 11:23:25 component_install|Initialize serviceability_common "from" side version|<LVL::Info>
12/23/2021 11:23:25 component_install|Component serviceability_common available on active side|<LVL::Debug>
12/23/2021 11:23:25 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:23:26 component_install|Got version 11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:23:26 component_install|Initialize serviceability_common "from" side version complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Initialize global data complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Build the command list for serviceability_common|<LVL::Info>
12/23/2021 11:23:26 component_install|Initialize command list|<LVL::Debug>
12/23/2021 11:23:26 component_install|Build serviceability_common export phase commands|<LVL::Debug>
12/23/2021 11:23:26 component_install|Processing serviceability_common export element|<LVL::Debug>
12/23/2021 11:23:26 component_install|Processing serviceability_common script element|<LVL::Debug>
12/23/2021 11:23:26 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:23:26 component_install|Add "cm_syslog_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_common /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:26 component_install|Add "cm_cdp_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_common /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:26 component_install|Add "cm_snmp_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_common /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:26 component_install|Building the command list for serviceability_common is complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Command execution for serviceability_common component RTMTStart|<LVL::Notice>
12/23/2021 11:23:26 component_install|Execute commands in the command list for serviceability_common component|<LVL::Info>
12/23/2021 11:23:26 component_install|Search path is /common/refresh_upgrade/Cisco/serviceability_common/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:23:26 component_install|Checking command /common/refresh_upgrade/Cisco/serviceability_common/scripts/cm_syslog_migration.sh|<LVL::Debug>
12/23/2021 11:23:26 component_install|Execute "/common/refresh_upgrade/Cisco/serviceability_common/scripts/cm_syslog_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_common /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:26 component_install|Checking command /common/refresh_upgrade/Cisco/serviceability_common/scripts/cm_cdp_migration.sh|<LVL::Debug>
12/23/2021 11:23:26 component_install|Execute "/common/refresh_upgrade/Cisco/serviceability_common/scripts/cm_cdp_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_common /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:26 component_install|Checking command /common/refresh_upgrade/Cisco/serviceability_common/scripts/cm_snmp_migration.sh|<LVL::Debug>
12/23/2021 11:23:26 component_install|Execute "/common/refresh_upgrade/Cisco/serviceability_common/scripts/cm_snmp_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_common /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:26 component_install|Command execution for serviceability_common component is complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Command execution for serviceability_common component RTMTFinish|<LVL::Notice>
12/23/2021 11:23:26 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:23:26 component_install|Initialize serviceability_callmanager "to" side version|<LVL::Info>
12/23/2021 11:23:26 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:23:26 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:23:26 component_install|Initialize serviceability_callmanager "to" side version complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Initialize serviceability_callmanager "from" side version|<LVL::Info>
12/23/2021 11:23:26 component_install|Component serviceability_callmanager available on active side|<LVL::Debug>
12/23/2021 11:23:26 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:23:26 component_install|Initialize serviceability_callmanager "from" side version complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Build the command list for serviceability_callmanager|<LVL::Info>
12/23/2021 11:23:26 component_install|Build serviceability_callmanager export phase commands|<LVL::Debug>
12/23/2021 11:23:26 component_install|Processing serviceability_callmanager export element|<LVL::Debug>
12/23/2021 11:23:26 component_install|Processing serviceability_callmanager script element|<LVL::Debug>
12/23/2021 11:23:26 component_install|Add "cm_servcli_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_callmanager /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:26 component_install|Building the command list for serviceability_callmanager is complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Command execution for serviceability_callmanager component RTMTStart|<LVL::Notice>
12/23/2021 11:23:26 component_install|Execute commands in the command list for serviceability_callmanager component|<LVL::Info>
12/23/2021 11:23:26 component_install|Search path is /common/refresh_upgrade/Cisco/serviceability_callmanager/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:23:26 component_install|Checking command /common/refresh_upgrade/Cisco/serviceability_callmanager/scripts/cm_servcli_migration.sh|<LVL::Debug>
12/23/2021 11:23:26 component_install|Execute "/common/refresh_upgrade/Cisco/serviceability_callmanager/scripts/cm_servcli_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/serviceability_callmanager /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:26 component_install|Command execution for serviceability_callmanager component is complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Command execution for serviceability_callmanager component RTMTFinish|<LVL::Notice>
12/23/2021 11:23:26 component_install|Initialize ucapp_common "to" side version|<LVL::Info>
12/23/2021 11:23:26 component_install|Initialize ucapp_common "to" side version complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Initialize ucapp_common "from" side version|<LVL::Info>
12/23/2021 11:23:26 component_install|Component ucapp_common available on active side|<LVL::Debug>
12/23/2021 11:23:26 component_install|Initialize ucapp_common "from" side version complete|<LVL::Info>
12/23/2021 11:23:26 component_install|Build the command list for ucapp_common|<LVL::Info>
12/23/2021 11:23:26 component_install|Build ucapp_common export phase commands|<LVL::Debug>
12/23/2021 11:23:26 component_install|Processing ucapp_common export element|<LVL::Debug>
12/23/2021 11:23:26 component_install|Processing ucapp_common script element|<LVL::Debug>
12/23/2021 11:23:26 component_install|Add "cm_reporter_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucapp_common /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:27 component_install|calculating timeout from script|<LVL::Debug>
12/23/2021 11:23:27 component_install|Add "ccmservice_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucapp_common /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:27 component_install|Building the command list for ucapp_common is complete|<LVL::Info>
12/23/2021 11:23:27 component_install|Command execution for ucapp_common component RTMTStart|<LVL::Notice>
12/23/2021 11:23:27 component_install|Execute commands in the command list for ucapp_common component|<LVL::Info>
12/23/2021 11:23:27 component_install|Search path is /common/refresh_upgrade/Cisco/ucapp_common/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:23:27 component_install|Checking command /common/refresh_upgrade/Cisco/ucapp_common/scripts/cm_reporter_migration.sh|<LVL::Debug>
12/23/2021 11:23:27 component_install|Execute "/common/refresh_upgrade/Cisco/ucapp_common/scripts/cm_reporter_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucapp_common /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:27 component_install|Checking command /common/refresh_upgrade/Cisco/ucapp_common/scripts/ccmservice_migration.sh|<LVL::Debug>
12/23/2021 11:23:27 component_install|Execute "/common/refresh_upgrade/Cisco/ucapp_common/scripts/ccmservice_migration.sh RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/ucapp_common /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:23:27 component_install|Command execution for ucapp_common component is complete|<LVL::Info>
12/23/2021 11:23:27 component_install|Command execution for ucapp_common component RTMTFinish|<LVL::Notice>
12/23/2021 11:23:27 component_install|Initialize component data, mode refresh-upgrade|<LVL::Info>
12/23/2021 11:23:27 component_install|Initialize connection "to" side version|<LVL::Info>
12/23/2021 11:23:27 component_install|Access "to" side API|<LVL::Debug>
12/23/2021 11:23:27 component_install|Got version 12.5.1.15900-38|<LVL::Debug>
12/23/2021 11:23:27 component_install|Initialize connection "to" side version complete|<LVL::Info>
12/23/2021 11:23:27 component_install|Initialize connection "from" side version|<LVL::Info>
12/23/2021 11:23:27 component_install|Component connection available on active side|<LVL::Debug>
12/23/2021 11:23:27 component_install|Access "from" side API|<LVL::Debug>
12/23/2021 11:23:27 component_install|Got version 11.5.1.12900-21|<LVL::Debug>
12/23/2021 11:23:27 component_install|Initialize connection "from" side version complete|<LVL::Info>
12/23/2021 11:23:27 component_install|Initialize global data complete|<LVL::Info>
12/23/2021 11:23:27 component_install|Build the command list for connection|<LVL::Info>
12/23/2021 11:23:27 component_install|Initialize command list|<LVL::Debug>
12/23/2021 11:23:27 component_install|Build connection export phase commands|<LVL::Debug>
12/23/2021 11:23:27 component_install|Processing connection export element|<LVL::Debug>
12/23/2021 11:23:27 component_install|Processing connection script element|<LVL::Debug>
12/23/2021 11:23:27 component_install|Add "cuc-export RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/connection /usr/local/cm/ /common/log/install/capture.txt" to command list|<LVL::Debug>
12/23/2021 11:23:27 component_install|Building the command list for connection is complete|<LVL::Info>
12/23/2021 11:23:27 component_install|Command execution for connection component RTMTStart|<LVL::Notice>
12/23/2021 11:23:27 component_install|Execute commands in the command list for connection component|<LVL::Info>
12/23/2021 11:23:27 component_install|Search path is /common/refresh_upgrade/Cisco/connection/scripts:/usr/local/cm/script|<LVL::Debug>
12/23/2021 11:23:27 component_install|Checking command /common/refresh_upgrade/Cisco/connection/scripts/cuc-export|<LVL::Debug>
12/23/2021 11:23:27 component_install|Execute "/common/refresh_upgrade/Cisco/connection/scripts/cuc-export RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/connection /usr/local/cm/ /common/log/install/capture.txt"|<LVL::Debug>
12/23/2021 11:25:30 component_install|Writing unity connection into /common/log/install/component_failed.xml file.|<LVL::Info>
12/23/2021 11:25:30 component_install|/common/log/install/component_failed.xml created : 0|<LVL::Info>
12/23/2021 11:25:30 component_install|(CAPTURE) Launching export|<LVL::Debug>
12/23/2021 11:25:30 component_install|(CAPTURE) Attempt to contact the subscriber server failed.|<LVL::Debug>
12/23/2021 11:25:30 component_install|(CAPTURE) |<LVL::Debug>
12/23/2021 11:25:30 component_install|File:/common/download/12.5.1.15900-38/Cisco/usr/cisco/bin/component_install:939, Function: execute_shell_cmd(), /common/refresh_upgrade/Cisco/connection/scripts/cuc-export RU Export 12.5.1.15900-38 11.5.1.12900-21 /common/component/connection /usr/local/cm/ /common/log/install/capture.txt failed (1)|<LVL::Error>
12/23/2021 11:25:30 refresh_upgrade|Final exit processing with result 1|<LVL::Info>
12/23/2021 11:25:30 refresh_upgrade|/common/download/12.5.1.15900-38/Cisco/bin/install_emailer not found!|<LVL::Info>
12/23/2021 11:25:30 refresh_upgrade|Exit processing with result 1|<LVL::Info>
12/23/2021 11:25:30 preflight|Starting preflight|<LVL::Info>
12/23/2021 11:25:30 preflight|Validate preflight data|<LVL::Info>
12/23/2021 11:25:30 preflight|Preflight data validation complete|<LVL::Info>
12/23/2021 11:25:30 preflight|Determine upgrade type|<LVL::Info>
12/23/2021 11:25:30 preflight|Active Base OS version = package centos-release-server is not installed|<LVL::Debug>
12/23/2021 11:25:30 preflight|New os version(xml) = 7Server|<LVL::Debug>
12/23/2021 11:25:30 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<LVL::Debug>
12/23/2021 11:25:35 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<LVL::Debug>
12/23/2021 11:25:35 preflight|HW model = VMware|<LVL::Debug>
12/23/2021 11:25:35 preflight|Upgrade type = RU|<LVL::Debug>
12/23/2021 11:25:35 preflight|Obtain product type|<LVL::Info>
12/23/2021 11:25:35 preflight|Obtained product type UnityConnection|<LVL::Info>
12/23/2021 11:25:35 preflight|Processing preflight cleanup mode|<LVL::Info>
12/23/2021 11:25:35 preflight|Clear preflight cancel utility|<LVL::Info>
12/23/2021 11:25:35 preflight|Removing /common/cancel_upgrade/preflight_cancel|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute cleanup preflight commands for UnityConnection:RU from /mnt/source/Cisco/install/preflight.xml|<LVL::Info>
12/23/2021 11:25:35 preflight|Found 7 preflight commands to execute|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute preflight command (1/7): rm -rf /usr/local/platform/conf/dynamicConfig.xml|<LVL::Debug>
12/23/2021 11:25:35 preflight|Preflight command returns 0|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute preflight command (2/7): cp -f /common/preflight/UC/RU/dynamicConfig.xml /usr/local/platform/conf/dynamicConfig.xml|<LVL::Debug>
[Fatal Error] :-1:-1: Premature end of file.
12/23/2021 11:25:35 preflight|Preflight command returns 1|<LVL::Debug>
12/23/2021 11:25:35 preflight|(CAPTURE) cp: cannot stat `/common/preflight/UC/RU/dynamicConfig.xml': No such file or directory|<LVL::Debug>
12/23/2021 11:25:35 preflight|Preflight command did not complete (1). Continuing command processing...|<LVL::Warn>
12/23/2021 11:25:35 preflight|Execute preflight command (3/7): rm -rf /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute preflight command (4/7): cp -f /common/preflight/UC/RU/dynamic.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
12/23/2021 11:25:35 preflight|(CAPTURE) cp: cannot stat `/common/preflight/UC/RU/dynamic.jsp': No such file or directory|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute preflight command (5/7): rm -rf /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute preflight command (6/7): cp -f /common/preflight/UC/RU/install-confirm-content.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
12/23/2021 11:25:35 preflight|(CAPTURE) cp: cannot stat `/common/preflight/UC/RU/install-confirm-content.jsp': No such file or directory|<LVL::Debug>
12/23/2021 11:25:35 preflight|Execute preflight command (7/7): rm -rf /common/preflight/UC/RU|<LVL::Debug>
12/23/2021 11:25:35 refresh_upgrade|IOWAIT monitor stopped|<LVL::Info>
12/23/2021 11:25:35 refresh_upgrade|Cleanup support directory|<LVL::Info>
12/23/2021 11:25:35 refresh_upgrade|Unmount /common/mnt/product_img|<LVL::Debug>
12/23/2021 11:25:35 refresh_upgrade|Cleanup mounted DVD or ISO|<LVL::Info>
12/23/2021 11:25:36 refresh_upgrade|Found mount point "/mnt/source" for source filesystem /dev/sr0|<LVL::Debug>
12/23/2021 11:25:36 refresh_upgrade|Unmount /mnt/source|<LVL::Debug>
12/23/2021 11:25:36 refresh_upgrade|Ejecting DVD (/dev/sr0)|<LVL::Debug>
12/23/2021 11:25:36 upgrade_install.sh|Cleaning up download...|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Cleanup upgrade source area.|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Ejecting DVD (/dev/sda1)|<LVL::Debug>
12/23/2021 11:25:36 upgrade_install.sh|Removing /common/download/12.5.1.15900-38|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Removing /common/cisco|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Started auditd...|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Started setroubleshoot...|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Changed selinux mode to enforcing|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Cleaning up rpm_archive...|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|Removing /common/rpm-archive/12.5.1.15900-38|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|IOWAIT monitor stopped|<LVL::Info>
12/23/2021 11:25:36 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:604, Function: main(), Upgrade Failed -- (1)|<LVL::Error>
12/23/2021 11:25:36 upgrade_install.sh|Parse argument status=upgrade.stage.error|<LVL::Debug>
12/23/2021 11:25:36 upgrade_install.sh|_set_upgrade_status_attribute: status set to upgrade.stage.error|<LVL::Debug>
12/23/2021 11:25:36 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
12/23/2021 11:25:36 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 25478).|<LVL::Debug>
12/23/2021 11:25:36 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 25478)|<LVL::Debug>
Installation of UCSInstall_CUC_12.5.1.15900-38.sgn.iso failed
An unknown error occurred while accessing the upgrade file.
A system reboot is required when the upgrade process completes or is canceled. This will ensure services affected by the upgrade process are functioning properly.
admin:
