04-28-2009 05:27 AM - edited 03-15-2019 05:42 PM
We need to have a VoIP solution for a small branch (under 20) office. We currently have Call Manager set up at our main site. Remote site will be VPN Site-to-sited with asa.
04-28-2009 05:34 AM
What is it about the project that you need input on? Design?
04-28-2009 05:50 AM
try with a UC520
java
if this helps, please rate
04-28-2009 05:56 AM
Deisgn, yes would be greatful
04-28-2009 06:01 AM
Well, 20 users remote across a VPN. You'll need an ASA/router to terminate the VPN between the two sites. You'll need phones and DLU's if you don't have enough DLU's already. I'd set them up for g.729. Do they have their own gateway at the other end? What analog needs to they have? Do all users need voicemail? Do you have enough voicemail licenses?
04-28-2009 08:05 AM
Thsi is from scratch. we will have an asa out there with a pipe back to the main office. main purpose is to switch a sip trunk at 12 hr block intervals from north america to australia to cover euro calls coming in 24x7.
