Remote Call Forward via a Call In Number
shiblyibrahim
Level 3
Level 3
Hey,
Recently a client of ours posed a requirement where they will like to call in and call forward the number. Is this possible?
I know we can do it via the User Option Page but can we dial in to a number (May be Unity) and then divert the call.
Thanks in advance
Shibly Ibrahim
Please rate the post Shibly Ibrahim
Jaime Valencia
If you're asking if there is some way to call in, and change the call forward settings???
No, we have no native means to do what you're asking, you would need to do custom development with something like UCCX to gather the details, and then some further programming to push that change into CUCM's DB. CUC cannot do any of what you ask for.
java
if this helps, please rate
Hi Jamie,
Yes thats correct. Call In and activate call forward and specifying the number to be forwarded to.
Thanks Jamie appreciate it.
Shibly Ibrahim
