Remote Call Forwarding
lordshawn
Scenario:
Have about 70 sites with a main number.   Each site wants to be able to call in with a cell phone and change forwarding.
Plan:
Use UCCX to accept calls and pass them or forward through. Write a script for each site to call in and change forwarding with Pin/site code. What do you think?
Jaime Valencia
That should work if you can have UCCX send the AXL request to change the config in CUCM as they need it.
java
if this helps, please rate
