Remote Destination Caller ID
JustForVoice_2
Level 4
Level 4
Hi All,
I am trying to configure some Mobility features, I am facing problem during the incoming call from remote destination to on of the IP phone in the cluster
the caller ID does not appear as if it is originated from the IP Phone unless I added the full remote destination number.
To make it clear: I have 2 IP phones 1) ext. 2000        2) ext 3000 and it has Remote Destination 4567890
what I am receiving from the PSTN is 1234567890 so that I configured the service parameter:
Matching Caller ID with remote destination to Partial Match
and the Number of Digits for Caller ID Partial Match to 7
but it does not work?
Any suggestion please
dijohn
Have you set "Matching Caller ID with Remote Destination" to partial??
From SRND
Matching Caller ID with Remote Destination (Default value: Complete Match)
This parameter specifies whether the caller ID of a configured remote destination is completely matched or partially matched by the system for inbound calls. Based on this setting, the caller ID is completely or partially matched to the destination number configured for each remote destination. If set to Partial Match, this parameter works in conjunction with the Number of Digits for Caller ID Partial Match service parameter to determine how many numbers in the presented caller ID will be matched. Caller ID matching determines whether the system recognizes the remote destination in order to invoke Enterprise Feature Access mid-call features and two-stage dialing as well as Mobile Voice Access.
Number of Digits for Caller ID Partial Match (Default value: 10)
This parameter determines how many consecutive digits of caller ID will be matched against configured remote destinations. This parameter is used only when the Matching Caller ID with Remote Destination service parameter is set to Partial Match.
From a knowledge forum.
What is the purpose of "Number of Digits" service
parameter?
     Service Param = Partial Match, 10 digits
      (Reset CCM and MVA service)
     BR1 GW CLID = 44 020 5943 2785
     Change HQ phone 2 remote destination to 11111102059432785
      PSTN dials into BR1 phone 2 "04 4793 3002"
      BR1 phone 2 show 4402059432785
Based on the above test the remote destination should have been matched
but it wasn't.
Maybe the number of digits is used to control how many digits is
required from the PSTN not which digits to match.  Because the PSTN is
sending 13 digits CLID the remote destination must match all 13 digits
but the remote destination can be equal length or longer.  CUCM is
configured to allow matching of only 10 digits if the PSTN only sent 10
digits.  But what would happen if the PSTN only sent 8 digits but CUCM
was configured to partially match 10, would the remote destination still
work?
BR1 GW CLID = 5943 2785 (reduced to 8 digits)
HQ phone 2 remote destination = +4402059432785
 BR1 phone 2 show +59432785
Change Service Param = Partial Match, 8 digits
 BR1 phone 2 show 4002
The answer is no.
The number of digits setting is used by CUCM to determine the minimum
length the CLID from the PSTN must be to match a remote destination.
Each digit from the PSTN must match a digit in the remote destination
starting from the right.  When CUCM was configured to partially match 10
digits but the PSTN was changed to only send 8 digits a remote
destination was not matched even though all digits were matched in the
remote destination number and the remote destination number was longer.
When the number of digits was changed to 8 the remote destination
matched.  This setting maybe useful in the event the PSTN sends a
different length CLID into different gate
dijohn
From SRND
parameter?
but it wasn't.
work?
The answer is no.
Thank you too much
I tested now and it is OK.
