07-17-2010 11:18 PM - last edited on 03-25-2019 08:00 PM by ciscomoderator
I'mfFinding it impossible to find configuration information that outlines how to configure the two NICS (teaming in HP model) and the management port (ILO) for the MCS 7845_I4 IBM equivelant.
Are both NIC's supported for CUCM 7.1.5 also have this I4 server for Unity Connection 7 / CUCM 7?
I vaguely remeber reading that redundant NICs for Unity connection wasnt supported, could this be correct???
Anyway if someone can point me to the doco for this it would be great.
MCS 7845-I4 - configure management port
MCS 7845-I4 Configure redundant Nics
Solved! Go to Solution.
07-19-2010 02:35 PM
Login to CUCM or Unity Connection CLI and add this command:
set network failover enable
07-19-2010 02:29 PM
07-19-2010 02:35 PM
10-28-2010 08:36 AM
Hello, the failover option works very well thanks.
How about the SYS MGMT port that is left on my MCS7825i4 machine?
I can't find any doc on this port and what it does in life, anyone know or have experience using it?
Thanks!
12-31-2010 06:21 AM
The IBM equivalent to ILO is called RSA, and in every case I've found it is supported but not included in the MCS78xx boxes.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/data_sheet_c78-478937.html
